LPC 2388 GPIO 3, 4 not working
am using mdk 5.17 for LPC2388 programming. In the debug session, the GPIO of ports 3 and 4 are not changing. Am trying to set and clear the GPIO ports with a delay.Ports 1 and 2 only changes the values , if its programmed as legacy port, it wont work in debug when programmed as FIO.
Some pins of port 3 and 4 wont change in the debug session(and trying to toggle all ports)..
even got the same problem in earlier version of mdk.
