I use STM32f103RCT6 to blinking led in pin A8 with 1 second delay, and i try to use logic analyzer to see whether it's right. However, when i setup in "Current Logic Analyzer Signal", i write PA.8 in it and it say "Unknown Signal". I was trying write everything "PORTA.8","PortA.8","PA8" but it always say "Unknown Signal". What signal' name i should write in it???
In order to use Logical Analyzer, you have to enable and setup correctly the Trace functionality.
Moreover, you can refer to this link www.keil.com/.../uv4_db_dbg_logicanalyzer_setupex.htm for the Logical Analyzer setup in details
"Variable "PORT0.2" Variable "PORT2", Mask: 0x10, Shift Right: 4 (Note, the input is identical to PORT2.4) Variable "flag", Mask: 0xFF, Shift Right: 0"
in this code example, where should i write this code in keil C. Can you please tell me more detail.
