'nTsel' node purpose in .uvopt project file
I am currently using Keil 4.7 for my development and planning to upgrad to Keil 5.17 (Latest).
I saw some difference in project file which is obvious when I open and close my current project solution.
Per analysis, if I open my current project file in Keil5.17 it gets modified, some nodes gets added/deleted.
I could figure out most of the node in .uvopt file which are modified but could not figure out which project setting could modify <nTsel> node in .uvopt file. Could any one please let me know for what project setting does <nTsel> node is used?
Thank you!
Paul
