I want to store a large image on external flash device (k9f1g08u0c, SAMSUNG NAND FLASH)...
In order to do this, I need programming algorithm for the flash, I don't know how to do that. I read the guides on www.keil.com/.../ulink2_su_newalgorithms.htm
But I do not have enough knowledge to write erase, programpage , and other necessary functions...
Any idea, guidance is very welcome ...
thanks
If you have MDK-ARM V5 installed refer to:
www.keil.com/.../_flash_algorithm.html
http://www.keil.com/support/docs/3656.htm
