Hello all,I have looked through the forum and did not find the solution for the issue. The problem is: ______config.h______ #define CFG 1234
_______
______start.s_______ ... VAR EQU CFG .... __________________ What have I add to project configuration to make CFG be seen in .s file?
Best regards,
Use a pre-compilation script to convert the .H to a .INC Look at command line defines passed in to the assembler Consider using a symbol
Most likely nothing. You've made it impossible to answer more specifically by neglecting to inform us what tool / architecture that configuration is supposed to be for.
