Hello All,
I am using uVision v5.15 targeting arm cortex processors. When I exit the application I get a windows (windows 7 Pro SP 1)error message saying that "uVision IDE has stopped working" with the following problem details:
Problem signature: Problem Event Name: BEX Application Name: UV4.exe Application Version: 5.15.0.0 Application Timestamp: 55684ac4 Fault Module Name: UvCC.dll_unloaded Fault Module Version: 0.0.0.0 Fault Module Timestamp: 547875f3 Exception Offset: 632e5ed0 Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: 0f31 Additional Information 2: 0f3137665bbf0bb676c8a16f3fa76e52 Additional Information 3: 7848 Additional Information 4: 784883cbb731593f2482c262a0598fce Read our privacy statement online: go.microsoft.com/.../ If the online privacy statement is not available, please read our privacy statement offline: C:\windows\system32\en-US\erofflps.txt
I have only just begun using this software, other than the error on application exit it seems to be working. I haven't been able to find any info on this problem and was hoping someone could suggest a solution. Thanks.
We did solve such an issue in MDK v5.17 that is now available for download.
Can you upgrade and see if the problem is gone?
Unfortunately I get the same problem with v5.17
Does this happen on every project or is that project specific?
It happens every time, even if there was no project opened.
And input method is not compatible, I was Google Pinyin caused by the problem. Unload input method, replaced by default input method can solve this problem.
