Using SDRAM MT48LC4M32B2-6 with LPC2478
Hello All,
1. I am interfacing SDRAM MT48LC4M32B2 with LPC2478. I am able to initialize it and test it in main() function without including it in scatter file.
Below is my problem statement........................................................
2. i want use it as DATA, HEAP and STACK sections. hence added in scatter file and initialised in LPC2400.s
but it can't work.
Below is scatter file................................................................
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x00000000 0x00080000 { ; load region size_region ER_IROM1 0x00000000 0x00080000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO)
RW_IRAM1 0x40000000 0x00010000
{ .ANY (+RW +ZI)
} RW_IRAM2 0x7FE00000 0x00004000 { .ANY (+RW +ZI)
RW_RAM1 0xA0000000 0x01000000 { ; RW data .ANY (+RW +ZI)
ARM_LIB_HEAP 0xA0100000 EMPTY 0x8000
ARM_LIB_STACK 0xA0110000 EMPTY -0x8000
} scatter file end.....................................................................
  • ; Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
    NO_EMC_SETUP EQU 0
    Mode_USR EQU 0x10
    Mode_FIQ EQU 0x11
    Mode_IRQ EQU 0x12
    Mode_SVC EQU 0x13
    Mode_ABT EQU 0x17
    Mode_UND EQU 0x1B
    Mode_SYS EQU 0x1F
    I_Bit EQU 0x80 ; when I bit is set, IRQ is disabled
    F_Bit EQU 0x40 ; when F bit is set, FIQ is disabled
    ;----------------------- Memory Definitions ------------------------------------
    ; Internal Memory Base Addresses
    FLASH_BASE EQU 0x00000000
    RAM_BASE EQU 0x40000000
    EXTMEM_BASE EQU 0x80000000
    ; External Memory Base Addresses
    STA_MEM0_BASE EQU 0x80000000
    STA_MEM1_BASE EQU 0x81000000
    STA_MEM2_BASE EQU 0x82000000
    STA_MEM3_BASE EQU 0x83000000
    DYN_MEM0_BASE EQU 0xA0000000
    DYN_MEM1_BASE EQU 0xB0000000
    DYN_MEM2_BASE EQU 0xC0000000
    DYN_MEM3_BASE EQU 0xD0000000
    ;----------------------- Stack and Heap Definitions ----------------------------
    ;// <h> Stack Configuration (Stack Sizes in Bytes)
    ;// <o0> Undefined Mode <0x0-0xFFFFFFFF:8>
    ;// <o1> Supervisor Mode <0x0-0xFFFFFFFF:8>
    ;// <o2> Abort Mode <0x0-0xFFFFFFFF:8>
    ;// <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:8>
    ;// <o4> Interrupt Mode <0x0-0xFFFFFFFF:8>
    ;// <o5> User/System Mode <0x0-0xFFFFFFFF:8>
    ;// </h>
    UND_Stack_Size EQU 0x00000100
    SVC_Stack_Size EQU 0x00000100
    ABT_Stack_Size EQU 0x00000100
    FIQ_Stack_Size EQU 0x00000100
    IRQ_Stack_Size EQU 0x00000100
    USR_Stack_Size EQU 0x00002000
    ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \ FIQ_Stack_Size + IRQ_Stack_Size)
    AREA STACK, NOINIT, READWRITE, ALIGN=4
    Stack_Mem SPACE USR_Stack_Size
    __initial_sp SPACE ISR_Stack_Size
    Stack_Top
    ;// <h> Heap Configuration
    ;// <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF>
    ;// </h>
    Heap_Size EQU 0x00000800
    AREA HEAP, NOINIT, READWRITE, ALIGN=4
    __heap_base
    Heap_Mem SPACE Heap_Size
    __heap_limit
    ;----------------------- Clock Definitions -------------------------------------
    ; System Control Block (SCB) Module Definitions
    SCB_BASE EQU 0xE01FC000 ; SCB Base Address
    PLLCON_OFS EQU 0x80 ; PLL Control Offset
    PLLCFG_OFS EQU 0x84 ; PLL Configuration Offset
    PLLSTAT_OFS EQU 0x88 ; PLL Status Offset
    PLLFEED_OFS EQU 0x8C ; PLL Feed Offset
    CCLKCFG_OFS EQU 0x104 ; CPU Clock Divider Reg Offset
    USBCLKCFG_OFS EQU 0x108 ; USB Clock Divider Reg Offset
    CLKSRCSEL_OFS EQU 0x10C ; Clock Source Sel Reg Offset
    SCS_OFS EQU 0x1A0 ; Sys Control and Status Reg Offset
    PCLKSEL0_OFS EQU 0x1A8 ; Periph Clock Sel Reg 0 Offset
    PCLKSEL1_OFS EQU 0x1AC ; Periph Clock Sel Reg 0 Offset
    PCON_OFS EQU 0x0C0 ; Power Mode Control Reg Offset
    PCONP_OFS EQU 0x0C4 ; Power Control for Periphs Reg Offset
    ; Constants
    OSCRANGE EQU (1<<4) ; Oscillator Range Select
    OSCEN EQU (1<<5) ; Main oscillator Enable
    OSCSTAT EQU (1<<6) ; Main Oscillator Status
    PLLCON_PLLE EQU (1<<0) ; PLL Enable
    PLLCON_PLLC EQU (1<<1) ; PLL Connect
    PLLSTAT_M EQU (0x7FFF<<0) ; PLL M Value
    PLLSTAT_N EQU (0xFF<<16) ; PLL N Value
    PLLSTAT_PLOCK EQU (1<<26) ; PLL Lock Status
    ;NO_CLOCK_SETUP EQU 0
    ;CLOCK_SETUP EQU 1
    SCS_Val EQU 0x00000021
    CLKSRCSEL_Val EQU 0x00000001
    PLLCFG_Val EQU 0x0001001F
    CCLKCFG_Val EQU 0x00000007
    USBCLKCFG_Val EQU 0x00000007
    PCLKSEL0_Val EQU 0x00000000
    PCLKSEL1_Val EQU 0x00000000
  • ;----------------------- Memory Accelerator Module (MAM) Definitions -----------
    MAM_BASE EQU 0xE01FC000 ; MAM Base Address
    MAMCR_OFS EQU 0x00 ; MAM Control Offset
    MAMTIM_OFS EQU 0x04 ; MAM Timing Offset
    ;// <e> MAM Setup
    ;// <o1.0..1> MAM Control
    ;// <0=> Disabled
    ;// <1=> Partially Enabled
    ;// <2=> Fully Enabled
    ;// Mode
    ;// <o2.0..2> MAM Timing
    ;// <0=> Reserved <1=> 1 <2=> 2 <3=> 3
    ;// <4=> 4 <5=> 5 <6=> 6 <7=> 7
    Fetch Cycles
    ;// </e>
    MAM_SETUP EQU 1
    MAMCR_Val EQU 0x00000000
    MAMTIM_Val EQU 0x00000004
    ;----------------------- Pin Connect Block Definitions -------------------------
    PCB_BASE EQU 0xE002C000 ; PCB Base Address
    PINSEL0_OFS EQU 0x00 ; PINSEL0 Address Offset
    PINSEL1_OFS EQU 0x04 ; PINSEL1 Address Offset
    PINSEL2_OFS EQU 0x08 ; PINSEL2 Address Offset
    PINSEL3_OFS EQU 0x0C ; PINSEL3 Address Offset
    PINSEL4_OFS EQU 0x10 ; PINSEL4 Address Offset
    PINSEL5_OFS EQU 0x14 ; PINSEL5 Address Offset
    PINSEL6_OFS EQU 0x18 ; PINSEL6 Address Offset
    PINSEL7_OFS EQU 0x1C ; PINSEL7 Address Offset
    PINSEL8_OFS EQU 0x20 ; PINSEL8 Address Offset
    PINSEL9_OFS EQU 0x24 ; PINSEL9 Address Offset
    PINSEL10_OFS EQU 0x28 ; PINSEL10 Address Offset
    ;----------------------- External Memory Controller (EMC) Definitons -----------
    EMC_BASE EQU 0xFFE08000 ; EMC Base Address
    EMC_CTRL_OFS EQU 0x000
    EMC_STAT_OFS EQU 0x004
    EMC_CONFIG_OFS EQU 0x008
    EMC_DYN_CTRL_OFS EQU 0x020
    EMC_DYN_RFSH_OFS EQU 0x024
    EMC_DYN_RD_CFG_OFS EQU 0x028
    EMC_DYN_RP_OFS EQU 0x030
    EMC_DYN_RAS_OFS EQU 0x034
    EMC_DYN_SREX_OFS EQU 0x038
    EMC_DYN_APR_OFS EQU 0x03C
    EMC_DYN_DAL_OFS EQU 0x040
    EMC_DYN_WR_OFS EQU 0x044
    EMC_DYN_RC_OFS EQU 0x048
    EMC_DYN_RFC_OFS EQU 0x04C
    EMC_DYN_XSR_OFS EQU 0x050
    EMC_DYN_RRD_OFS EQU 0x054
    EMC_DYN_MRD_OFS EQU 0x058
    EMC_DYN_CFG0_OFS EQU 0x100
    EMC_DYN_RASCAS0_OFS EQU 0x104
    EMC_DYN_CFG1_OFS EQU 0x140
    EMC_DYN_RASCAS1_OFS EQU 0x144
    EMC_DYN_CFG2_OFS EQU 0x160
    EMC_DYN_RASCAS2_OFS EQU 0x164
    EMC_DYN_CFG3_OFS EQU 0x180
    EMC_DYN_RASCAS3_OFS EQU 0x184
    EMC_STA_CFG0_OFS EQU 0x200
    EMC_STA_WWEN0_OFS EQU 0x204
    EMC_STA_WOEN0_OFS EQU 0x208
    EMC_STA_WRD0_OFS EQU 0x20C
    EMC_STA_WPAGE0_OFS EQU 0x210
    EMC_STA_WWR0_OFS EQU 0x214
    EMC_STA_WTURN0_OFS EQU 0x218
    EMC_STA_CFG1_OFS EQU 0x220
    EMC_STA_WWEN1_OFS EQU 0x224
    EMC_STA_WOEN1_OFS EQU 0x228
    EMC_STA_WRD1_OFS EQU 0x22C
    EMC_STA_WPAGE1_OFS EQU 0x230
    EMC_STA_WWR1_OFS EQU 0x234
    EMC_STA_WTURN1_OFS EQU 0x238
    EMC_STA_CFG2_OFS EQU 0x240
    EMC_STA_WWEN2_OFS EQU 0x244
    EMC_STA_WOEN2_OFS EQU 0x248
    EMC_STA_WRD2_OFS EQU 0x24C
    EMC_STA_WPAGE2_OFS EQU 0x250
    EMC_STA_WWR2_OFS EQU 0x254
    EMC_STA_WTURN2_OFS EQU 0x258
    EMC_STA_CFG3_OFS EQU 0x260
    EMC_STA_WWEN3_OFS EQU 0x264
    EMC_STA_WOEN3_OFS EQU 0x268
    EMC_STA_WRD3_OFS EQU 0x26C
    EMC_STA_WPAGE3_OFS EQU 0x270
    EMC_STA_WWR3_OFS EQU 0x274
    EMC_STA_WTURN3_OFS EQU 0x278
    EMC_STA_EXT_W_OFS EQU 0x080
    ; Constants
    NORMAL_CMD EQU (0x0 << 7) ; NORMAL Command
    MODE_CMD EQU (0x1 << 7) ; MODE Command
    PALL_CMD EQU (0x2 << 7) ; Precharge All Command
    NOP_CMD EQU (0x3 << 7) ; NOP Command
    BUFEN_Const EQU (1 << 19) ; Buffer enable bit
    EMC_PCONP_Const EQU (1 << 11) ; PCONP val to enable power for EMC
    ; External Memory Pins definitions
    ; pin functions for SDRAM, NOR and NAND flash interfacing
    EMC_PINSEL5_Val EQU 0x55010115 ; !AS, RAS, CLKOUT0, DYCS0, DQMOUT0, DQMOUT1, DQMOUT2, DQMOUT3
    EMC_PINSEL6_Val EQU 0x55555555 ; D0 .. D15
    EMC_PINSEL7_Val EQU 0x55555555 ; D16..D31
    EMC_PINSEL8_Val EQU 0x14555555 ;santosh 0x55555555 ; A0 .. A15
    EMC_PINSEL9_Val EQU 0x00040000 ;santosh 0x50055555; ; WE
    ;// External Memory Controller Setup (EMC) ---------------------------------
    ;// <e> External Memory Controller Setup (EMC)
    EMC_SETUP EQU 1
    ;// <h> EMC Control Register (EMCControl)
    ;// Controls operation of the memory controller
    ;// <o0.2> L: Low-power mode enable
    ;// <o0.1> M: Address mirror enable
    ;// <o0.0> E: EMC enable
    ;// </h>
    EMC_CTRL_Val EQU 0x00000001
    ;// <h> EMC Configuration Register (EMCConfig)
    ;// Configures operation of the memory controller
    ;// <o0.8> CCLK: CLKOUT ratio
    ;// <0=> 1:1
    ;// <1=> 1:2
    ;// <o0.0> Endian mode
    ;// <0=> Little-endian
    ;// <1=> Big-endian
    ;// </h>
    EMC_CONFIG_Val EQU 0x00000000
  • ;// Dynamic Memory Interface Setup ---------------------------------------
    ;// <e> Dynamic Memory Interface Setup
    EMC_DYNAMIC_SETUP EQU 1
    EMC_STATIC_SETUP EQU 0
    ;// <h> Dynamic Memory Refresh Timer Register (EMCDynamicRefresh)
    ;// Configures dynamic memory refresh operation
    ;// <o0.0..10> REFRESH: Refresh timer <0x000-0x7FF>
    0 = refresh disabled, 0x01-0x7FF: value * 16 CCLKS
    ;// </h>
    EMC_DYN_RFSH_Val EQU 0x000007FF;01C
    ;// <h> Dynamic Memory Read Configuration Register (EMCDynamicReadConfig)
    ;// Configures the dynamic memory read strategy
    ;// <o0.0..1> RD: Read data strategy
    ;// <0=> Clock out delayed strategy
    ;// <1=> Command delayed strategy
    ;// <2=> Command delayed strategy plus one clock cycle
    ;// <3=> Command delayed strategy plus two clock cycles
    ;// </h>
    EMC_DYN_RD_CFG_Val EQU 0x00000001
    EMC_DYN_RP_Val EQU 0x00000002
    EMC_DYN_RAS_Val EQU 0x00000003
    EMC_DYN_SREX_Val EQU 0x00000007
    EMC_DYN_APR_Val EQU 0x00000002
    EMC_DYN_DAL_Val EQU 0x00000005
    EMC_DYN_WR_Val EQU 0x00000001
    EMC_DYN_RC_Val EQU 0x00000005
    EMC_DYN_RFC_Val EQU 0x00000005
    EMC_DYN_XSR_Val EQU 0x00000007
    EMC_DYN_RRD_Val EQU 0x00000001
    EMC_DYN_MRD_Val EQU 0x00000002
    ;// <e> Configure External Bus Behaviour for Dynamic CS0 Area
    EMC_DYNCS0_SETUP EQU 1
    EMC_DYNCS1_SETUP EQU 0
    EMC_DYNCS2_SETUP EQU 0
    EMC_DYNCS3_SETUP EQU 0
    EMC_DYN_CFG0_Val EQU 0x00084400 ;0x00004680
    ;// <h> Dynamic Memory RAS & CAS Delay register (EMCDynamicRASCAS0)
    ;// Controls the RAS and CAS latencies for the dynamic memory CS0
    ;// <o0.8..9> CAS: CAS latency
    ;// <1=> One CCLK cycle
    ;// <2=> Two CCLK cycles
    ;// <3=> Three CCLK cycles
    ;// <o0.0..1> RAS: RAS latency (active to read/write delay)
    ;// </h>
    EMC_DYN_RASCAS0_Val EQU 0x00000202 ;santosh 0x00000303
    ;// </e> End of Dynamic Setup for CS0 Area
    ;// </e> End of EMC Setup
    PRESERVE8
    ; Area Definition and Entry Point
    ; Startup Code must be linked first at Address at which it expects to run.
    AREA RESET, CODE, READONLY ARM
    ;IMPORT |Image$$ARM_LIB_STACK$$ZI$$Limit| ;IMPORT |Image$$ARM_LIB_HEAP$$ZI$$Limit|
    ; Exception Vectors
    ; Mapped to Address 0.
    ; Absolute addressing mode must be used.
    ; Dummy Handlers are implemented as infinite loops which can be modified.
    Vectors ;LDR PC, Image$$ARM_LIB_STACK$$ZI$$Limit LDR PC, Reset_Addr LDR PC, Undef_Addr LDR PC, SWI_Addr LDR PC, PAbt_Addr LDR PC, DAbt_Addr NOP ; Reserved Vector
    ; LDR PC, IRQ_Addr LDR PC, [PC, #-0x0120] ; Vector from VicVectAddr LDR PC, FIQ_Addr
    Reset_Addr DCD Reset_Handler
    Undef_Addr DCD Undef_Handler
    SWI_Addr DCD SWI_Handler
    PAbt_Addr DCD PAbt_Handler
    DAbt_Addr DCD DAbt_Handler
    DCD 0 ; Reserved Address 0xB8A06F60
    IRQ_Addr DCD IRQ_Handler
    FIQ_Addr DCD FIQ_Handler
    IMPORT SWI_Handler
    Undef_Handler B Undef_Handler
    ;SWI_Handler B SWI_Handler
    PAbt_Handler B PAbt_Handler
    DAbt_Handler B DAbt_Handler
    IRQ_Handler B IRQ_Handler
    FIQ_Handler B FIQ_Handler
    ; Reset Handler
    EXPORT Reset_Handler
    Reset_Handler
  • ; Clock Setup ------------------------------------------------------------------
    ; IF (:LNOT:(:DEF:NO_CLOCK_SETUP)):LAND:(CLOCK_SETUP != 0) LDR R0, =SCB_BASE MOV R1, #0xAA MOV R2, #0x55
    ; Configure and Enable PLL LDR R3, =SCS_Val ; Enable main oscillator STR R3, [R0, #SCS_OFS]
    IF (SCS_Val:AND:OSCEN) != 0
    OSC_Loop LDR R3, [R0, #SCS_OFS] ; Wait for main osc stabilize ANDS R3, R3, #OSCSTAT BEQ OSC_Loop ENDIF
    LDR R3, =CLKSRCSEL_Val ; Select PLL source clock STR R3, [R0, #CLKSRCSEL_OFS] LDR R3, =PLLCFG_Val STR R3, [R0, #PLLCFG_OFS] STR R1, [R0, #PLLFEED_OFS] STR R2, [R0, #PLLFEED_OFS] MOV R3, #PLLCON_PLLE STR R3, [R0, #PLLCON_OFS] STR R1, [R0, #PLLFEED_OFS] STR R2, [R0, #PLLFEED_OFS]
    IF (CLKSRCSEL_Val:AND:3) != 2
    ; Wait until PLL Locked (if source is not RTC oscillator)
    PLL_Loop LDR R3, [R0, #PLLSTAT_OFS] ANDS R3, R3, #PLLSTAT_PLOCK BEQ PLL_Loop ELSE
    ; Wait at least 200 cycles (if source is RTC oscillator) MOV R3, #(200/4)
    PLL_Loop SUBS R3, R3, #1 BNE PLL_Loop ENDIF
    M_N_Lock LDR R3, [R0, #PLLSTAT_OFS] LDR R4, =(PLLSTAT_M:OR:PLLSTAT_N) AND R3, R3, R4 LDR R4, =PLLCFG_Val EORS R3, R3, R4 BNE M_N_Lock
    ; Setup CPU clock divider MOV R3, #CCLKCFG_Val STR R3, [R0, #CCLKCFG_OFS]
    ; Setup USB clock divider LDR R3, =USBCLKCFG_Val STR R3, [R0, #USBCLKCFG_OFS]
    ; Setup Peripheral Clock LDR R3, =PCLKSEL0_Val STR R3, [R0, #PCLKSEL0_OFS] LDR R3, =PCLKSEL1_Val STR R3, [R0, #PCLKSEL1_OFS]
    ; Switch to PLL Clock MOV R3, #(PLLCON_PLLE:OR:PLLCON_PLLC) STR R3, [R0, #PLLCON_OFS] STR R1, [R0, #PLLFEED_OFS] STR R2, [R0, #PLLFEED_OFS]
    ; ENDIF ; CLOCK_SETUP
    ; Setup Memory Accelerator Module ----------------------------------------------
    IF MAM_SETUP != 0 LDR R0, =MAM_BASE MOV R1, #MAMTIM_Val STR R1, [R0, #MAMTIM_OFS] MOV R1, #MAMCR_Val STR R1, [R0, #MAMCR_OFS] ENDIF ; MAM_SETUP
    ; Setup External Memory Controller ---------------------------------------------
    ; IF (:LNOT:(:DEF:NO_EMC_SETUP)):LAND:(EMC_SETUP != 0) LDR R0, =EMC_BASE LDR R1, =SCB_BASE LDR R2, =PCB_BASE
    LDR R4, =EMC_PCONP_Const ; Enable EMC LDR R3, [R1, #PCONP_OFS] ORR R4, R4, R3 STR R4, [R1, #PCONP_OFS]
    LDR R4, =EMC_CTRL_Val STR R4, [R0, #EMC_CTRL_OFS] LDR R4, =EMC_CONFIG_Val STR R4, [R0, #EMC_CONFIG_OFS]
    ; Setup pin functions for External Bus functionality LDR R4, =EMC_PINSEL5_Val STR R4, [R2, #PINSEL5_OFS] LDR R4, =EMC_PINSEL6_Val STR R4, [R2, #PINSEL6_OFS] LDR R4, =EMC_PINSEL7_Val STR R4, [R2, #PINSEL7_OFS] LDR R4, =EMC_PINSEL8_Val STR R4, [R2, #PINSEL8_OFS] LDR R4, =EMC_PINSEL9_Val STR R4, [R2, #PINSEL9_OFS]
    ; Setup Dynamic Memory Interface ; IF (EMC_DYNAMIC_SETUP != 0)
    LDR R4, =EMC_DYN_RP_Val STR R4, [R0, #EMC_DYN_RP_OFS] LDR R4, =EMC_DYN_RAS_Val STR R4, [R0, #EMC_DYN_RAS_OFS] LDR R4, =EMC_DYN_SREX_Val STR R4, [R0, #EMC_DYN_SREX_OFS] LDR R4, =EMC_DYN_APR_Val STR R4, [R0, #EMC_DYN_APR_OFS] LDR R4, =EMC_DYN_DAL_Val STR R4, [R0, #EMC_DYN_DAL_OFS] LDR R4, =EMC_DYN_WR_Val STR R4, [R0, #EMC_DYN_WR_OFS] LDR R4, =EMC_DYN_RC_Val STR R4, [R0, #EMC_DYN_RC_OFS] LDR R4, =EMC_DYN_RFC_Val STR R4, [R0, #EMC_DYN_RFC_OFS] LDR R4, =EMC_DYN_XSR_Val STR R4, [R0, #EMC_DYN_XSR_OFS] LDR R4, =EMC_DYN_RRD_Val STR R4, [R0, #EMC_DYN_RRD_OFS] LDR R4, =EMC_DYN_MRD_Val STR R4, [R0, #EMC_DYN_MRD_OFS]
    LDR R4, =EMC_DYN_RD_CFG_Val STR R4, [R0, #EMC_DYN_RD_CFG_OFS]
    IF (EMC_DYNCS0_SETUP != 0) LDR R4, =EMC_DYN_RASCAS0_Val STR R4, [R0, #EMC_DYN_RASCAS0_OFS] LDR R4, =EMC_DYN_CFG0_Val MVN R5, #BUFEN_Const AND R4, R4, R5 STR R4, [R0, #EMC_DYN_CFG0_OFS] ENDIF
    LDR R6, =1440000 ; Number of cycles to delay
    Wait_0 SUBS R6, R6, #1 ; Delay ~100 ms proc clk 57.6 MHz BNE Wait_0 ; BNE (3 cyc) + SUBS (1 cyc) = 4 cyc
    LDR R4, =(NOP_CMD:OR:0x03) ; Write NOP Command STR R4, [R0, #EMC_DYN_CTRL_OFS]
    LDR R6, =2880000 ; Number of cycles to delay
    Wait_1 SUBS R6, R6, #1 ; Delay ~200 ms proc clk 57.6 MHz BNE Wait_1
    LDR R4, =(PALL_CMD:OR:0x03) ; Write Precharge All Command STR R4, [R0, #EMC_DYN_CTRL_OFS]
    MOV R4, #2 STR R4, [R0, #EMC_DYN_RFSH_OFS]
    MOV R6, #64 ; Number of cycles to delay
    Wait_2 SUBS R6, R6, #1 ; Delay BNE Wait_2
    LDR R4, =EMC_DYN_RFSH_Val STR R4, [R0, #EMC_DYN_RFSH_OFS]
    LDR R4, =(MODE_CMD:OR:0x03) ; Write MODE Command STR R4, [R0, #EMC_DYN_CTRL_OFS]
    ; Dummy read (set SDRAM Mode register) IF (EMC_DYNCS0_SETUP != 0) LDR R4, =DYN_MEM0_BASE ;LDR R5, =(EMC_DYN_RASCAS0_Val:AND:0x00000300) ; get CAS Latency ;LSR R5, #4 ; set CAS Latency (Bit4..6) LDR R5, =(0x22) ;IF ((EMC_DYN_CFG0_Val:AND:0x00004000) != 0) ;ORR R5, R5, #0x02 ; set burst length 4 (Bit0..2) LSL R5, #12 ;ELSE ;ORR R5, R5, #0x03 ; set burst length 8 (Bit0..2) ;LSL R5, #12 ;ENDIF ADD R4, R4, R5 LDR R4, [R4, #0] ENDIF
    LDR R4, =NORMAL_CMD ; Write NORMAL Command STR R4, [R0, #EMC_DYN_CTRL_OFS]
    ; Enable buffer if requested by settings ;IF (EMC_DYNCS0_SETUP != 0):LAND:((0x00080000:AND:BUFEN_Const) != 0);EMC_DYN_CFG0_Val LDR R4, =(0x00084500);EMC_DYN_CFG0_Val STR R4, [R0, #EMC_DYN_CFG0_OFS] ;ENDIF
    LDR R6, =1440000;14400 ; Number of cycles to delay
    Wait_3 SUBS R6, R6, #1 ; Delay ~1 ms @ proc clk 57.6 MHz BNE Wait_3
    ; ENDIF ; EMC_DYNAMIC_SETUP
    ; Setup Static Memory Interface
    ; ENDIF ; EMC_SETUP
  • ; Copy Exception Vectors to Internal RAM ---------------------------------------
    IF :DEF:RAM_INTVEC ADR R8, Vectors ; Source LDR R9, =RAM_BASE ; Destination LDMIA R8!, {R0-R7} ; Load Vectors STMIA R9!, {R0-R7} ; Store Vectors LDMIA R8!, {R0-R7} ; Load Handler Addresses STMIA R9!, {R0-R7} ; Store Handler Addresses ENDIF
    ; Memory Mapping (when Interrupt Vectors are in RAM) ---------------------------
    MEMMAP EQU 0xE01FC040 ; Memory Mapping Control IF :DEF:REMAP LDR R0, =MEMMAP IF :DEF:EXTMEM_MODE MOV R1, #3 ELIF :DEF:RAM_MODE MOV R1, #2 ELSE MOV R1, #1 ENDIF STR R1, [R0] ENDIF
    ; Setup Stack for each mode ----------------------------------------------------
    LDR R0, =Stack_Top
    ; Enter Undefined Instruction Mode and set its Stack Pointer MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #UND_Stack_Size
    ; Enter Abort Mode and set its Stack Pointer MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #ABT_Stack_Size
    ; Enter FIQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #FIQ_Stack_Size
    ; Enter IRQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #IRQ_Stack_Size
    ; Enter Supervisor Mode and set its Stack Pointer MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #SVC_Stack_Size
    ; Enter User Mode and set its Stack Pointer MSR CPSR_c, #Mode_USR IF :DEF:__MICROLIB
    EXPORT __initial_sp
    ELSE
    MOV SP, R0 SUB SL, SP, #USR_Stack_Size
    ENDIF
    ; Enter the C code -------------------------------------------------------------
    IMPORT __main LDR R0, =__main BX R0
    IF :DEF:__MICROLIB
    EXPORT __heap_base EXPORT __heap_limit
    ELSE
    ; User Initial Stack & Heap ALIGN 4 AREA |.text|, CODE, READONLY
    IMPORT __use_two_region_memory EXPORT __user_initial_stackheap
    LDR R0, = Heap_Mem LDR R1, = (Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ENDIF
    END
  • I HAVE ADDED SCATTER FILE AND START UP FILE IN MULTIPLE PART, I WAS NOT ABLE TO ADD ONCE ALL.
  • Pity you didn't read the posting instructions for source code, or consider using something like pastebin
    Before you try to get Keil to place data in the SDRAM you'd be much better validating your initialization code, and TESTING the memory integrity first. If this is a board you have designed you will need to pay attention to the circuit and pins used, and the clock rates, and the geometry and speed of the SDRAM.
  • Turn off "Run to main()" and step/analyze your startup code with a debugger.
