BOLD
#define A 100
void main()
{ int b=0;
int c=30;
while(1)
{ b++;
if(b>1000) b=0; if(abs(b-c)>10) { #ifdef A #undef A #define A 200 #endif
print("A1= %d",A); }
else { #ifdef A #undef A #define A 300 #endif
print("A2= %d",A); }
taget result A1 =200 A2 = 300
I want to ask,
Dos the #undef rules meet The C standard specifies?
thank you
  • To view the results of the defines, you can look at the output of the preprocessor in a file:
    http://www.keil.com/support/man/docs/c51/c51_cm_ifile.htm
    That way you can see what the results of the #ifdefs.
  • Nothing strange with #undef.
    The defined symbols are just a text-based cut and paste in your source code, while the #undef keeps the preprocessor happy that you aren't accidentally trying to clash preprocessor symbol names.
    But how is "BOLD" a summary of your post, that may help other readers to understand what this thread is about?
  • Sorry for the summary type error, the summary should be "Question of Keil C complier Preprocessor"
    but the Preprocessor I put it in if…else statement
    I think the complier Preprocessor won't know what the variable it is . so I think the code will not print correct target data , but In a fact it's work fine , so I don't understand why?
    Many Thanks for your answer ...
  • But maybe you should spend some time and tell what you think - and more importantly why you think - this should, or shouldn't function.
    #define A 100
    void main() {
        int b=0;
        int c=30;
        while (1) {
            b++;
            if (b > 1000) b=0;
            if (abs(b-c)>10) {
    #ifdef A
        #undef A
        #define A 200
    #endif
                print("A1= %d",A);
            } else {
    #ifdef A
        #undef A
        #define A 300
    #endif
                print("A2= %d",A);
    Note that the preprocessor does not care about any logical conditions or identations of the C/C++ source code. So the "if (abs(b-c)>10)" condition is irrelevant.
    The preprocessor just walks down the code text line for text line.
    This is what the C compiler sees:
     <=== empty line where the preprocessor define was
    void main() {
        int b=0;
        int c=30;
        while (1) {
            b++;
            if (b > 1000) b=0;
            if (abs(b-c)>10) {
      <==== empty lines where your #ifdef/#endif section was
                print("A1= %d",200);
            } else {
                print("A2= %d",300);
    Never think you can mix C flow control with preprocessor statements, since the preprocessor is just a glorious "search-replace" engine that performs the task before the C compiler starts to split the code into tokens for processing.
    Note, by the way, that it helps to use the proper tags when posting source code.
