i am using three variables for delay function these three variables are used to calculate specific delay in which dynamically varied in from 1-100 according to the user input.kindly find my below code.in which my delay funcion is not working #include "stm32f0xx.h"
#define BSRR_VAL 0x0300
int u=100,min_value=280,max_value=28000;
void on_time(int ontime);
int main(void) {
RCC->AHBENR |= RCC_AHBENR_GPIOCEN; GPIOC->MODER |= (GPIO_MODER_MODER8_0) ; GPIOC->OTYPER &= ~(GPIO_OTYPER_OT_8) ; GPIOC->OSPEEDR |= (GPIO_OSPEEDER_OSPEEDR8); GPIOC->PUPDR = ~(GPIO_PUPDR_PUPDR8);
while (1) { /* Set PC8 and PC9 */ GPIOC->BSRR = BSRR_VAL; on_time();
/* Reset PC8 and PC9 */ GPIOC->BRR = BSRR_VAL; on_time();
void on_time() { unsigned int y,ontime;
ontime=u*y;
if i enter a value in u(100) it should be max value.i will be varying this variable from 1-100 such a way that it should be my max delay(10msec)
Your delay code isn't working because you haven't written it yet.
Assigning a value to a variable doesn't give you any configurable delay.
can u kindly send me the code that what i should give as i am a starter of this controller
But from your specified MCU architecture, your processor doesn't seem to be supported by Keil...
sir i am working on STM32f030 family
Are you new with just this controller or are you also new to C?
I can write code.
k sir kindly write the code also....
