1- how to change IP address in runtime in microcontroller.
2- Can this network stack work without RTX or RTOS?
3- Can we call BSD socket functions from different threads in RTX?
http://www.keil.com/support/man/docs/rlarm/rlarm_tn_runtimecfg.htm
www.keil.com/.../rlarm_tn_using_withkernel.htm
http://www.keil.com/support/man/docs/rlarm/rlarm_tn_bsd_funcs.htm
You appear to be deficient in your searching skills. For the two threads of yours that I've replied to, I managed to get appropriate detail with no difficulty.
I leave it as an exercise for you to find the details you will need to fully appreciate what you're actually asking.
it seems the above links is related to keil ver4, but I need info on keil ver5 and Keil.MDK-Middleware.6.5.0.pack.
Thanks for your help.
<facepalm>
