Hi all, i'm trying to use emWin librarie with keil rtos and i have some problems. First, i use a STM32F7 discovery with a touch screen. For my project, i started with the GUIDemo (keil package exemple). I remove all the exemple and build a new one adapt for me. It work fine if i let GUI_Exec() in an infinite loop (in the main). Below the working code :
int main (void) { CPU_CACHE_Enable(); /* Enable the CPU Cache */ HAL_Init(); /* Initialize the HAL Library */ BSP_SDRAM_Init(); /* Initialize BSP SDRAM */ SystemClock_Config(); /* Configure the System Clock */ MainTask(); GUI_Exec(); for (;;); }
Now, if i try to use thread (semaphore), i'm doing this :
int main (void) { CPU_CACHE_Enable(); /* Enable the CPU Cache */ HAL_Init(); /* Initialize the HAL Library */ BSP_SDRAM_Init(); /* Initialize BSP SDRAM */ SystemClock_Config(); /* Configure the System Clock */ MainTask(); GUI_Exec(); //need to let one guiExec here else i have a black screen osKernelInitialize (); Init_Semaphore (); osKernelStart (); }
the semaphore :
#include <cmsis_os.h> // CMSIS RTOS header file #include "GUI.h" /*---------------------------------------------------------------------------- * Semaphore creation & usage *---------------------------------------------------------------------------*/ void Thread_Semaphore (void const *argument); // thread function osThreadId tid_Thread_Semaphore; // thread id osThreadDef (Thread_Semaphore, osPriorityNormal, 1, 0); // thread object osSemaphoreId sid_Thread_Semaphore; // semaphore id osSemaphoreDef (SampleSemaphore); // semaphore object int Init_Semaphore (void) { sid_Thread_Semaphore = osSemaphoreCreate(osSemaphore(SampleSemaphore), 1); if (!sid_Thread_Semaphore) { ; // Semaphore object not created, handle failure } tid_Thread_Semaphore = osThreadCreate (osThread(Thread_Semaphore), NULL); if(!tid_Thread_Semaphore) return(-1); return(0); } void Thread_Semaphore(void const *argument) { int32_t val; while(1) { GUI_Exec(); // Insert thread code here... val = osSemaphoreWait (sid_Thread_Semaphore, 10); // wait 10 mSec switch (val) { case osOK: // Use protected code here... osSemaphoreRelease (sid_Thread_Semaphore); // Return a token back to a semaphore break; case osErrorResource: break; case osErrorParameter: break; default: break; } osThreadYield(); // suspend thread } }
The application start but when i touch the screen, the application freeze and i have an os_error (not identify) ! Ihave tried with thread but same result ! For information in GUIConf ihave :
#define GUI_OS 1
Do you know how i can resolve this ?
