Any one working on nxp 89v51rd2 ... i want to know how to wirte 'c' program for IAP ....thanks
i have been writing programs in assembly only ... IAP is working fine in assembly... now translated entire program in C ... working fine ... now the problem is how to write c code for IAP ...bcz.. IAP is using registers ....
Did you try google?
www.lmgtfy.com
Or, If it's a problem for you, why not just write the low-level functions in assembler, and then call them from 'C' ?
Here's an example of creating a 'C'-callable ASM function: www.8052.com/.../149030
Thanks a lot Mr Andrew Neil. I have gone thru both the links that u have given.... i think i can now certainly do it..... using SRC directive.... with regards...
