Problem reading DS1307
I am using the DS1307 library for STM32L152. The original library for STM32F429 is at here:
stm32f4-discovery.com/.../
It seems a complete library however after few modification to STM32L I cant read/write DS1307.
what ever is received is 1.
int main(void)
        TM_DS1307_Time_t tim;
        SystemCoreClockSetHSI();
        GPIO_RCC_configuration();
        GPIO_configuration();
        Init_SPI();
        uart1_configuration();
        I2C2_init();
        TIM4_configuration();
        TM_DS1307_SetDateTime(&tim);
        while(1)
                tim.seconds=TM_DS1307_GetSeconds();
                sprintf(str," \r\ns=%u",tim.seconds);
                uart_out_str(str);
                delay_ms(1000);
result is
s=1
s=1
s=1
s=1
s=1
s=1
I see signals in scope and there is a delay about 200ms when reading from DS1307 (reading timeout). when I debug, DR changes between 0xD0 and 0xD1. How can I find where the problem is?
  • The problem is at start function. ((/* Wait till I2C is busy */)) program waits till TM_I2C_Timeout equals zero.
    int16_t TM_I2C_Start(I2C_TypeDef* I2Cx, uint8_t address, uint8_t direction, uint8_t ack) {
            /* Generate I2C start pulse */
            I2Cx->CR1 |= I2C_CR1_START;
            TM_I2C_Timeout = TM_I2C_TIMEOUT;
            while (!(I2Cx->SR1 & I2C_SR1_SB)) {
                    if (--TM_I2C_Timeout == 0x00) {
                            return 1;
            /* Enable ack if we select it */
            if (ack) {
                    I2Cx->CR1 |= I2C_CR1_ACK;
            /* Send write/read bit */
            if (direction == I2C_TRANSMITTER_MODE) {
                    /* Send address with zero last bit */
                    I2Cx->DR = address & ~I2C_OAR1_ADD0;
                    /* Wait till finished */
                    while (!(I2Cx->SR1 & I2C_SR1_ADDR)) {
                                    return 1;
            if (direction == I2C_RECEIVER_MODE) {
                    /* Send address with 1 last bit */
                    I2Cx->DR = address | I2C_OAR1_ADD0;
                    while (!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)) {
                                    return 1;
  • Have you enabled the I2C peripheral clock?
    Can you see the peripheral registers in the debugger?
    Have you spoken to the author of the library?
  • Hi,
    I2C Peripheral clock is enabled and I see the signals in scope.
    Yes I see peripheral registers in debugger they change according to the program flow.
    No, I have not yet spoken to him. I think problem is at start function. because program waits there, I2C looks so busy.
                            return 1;
  • I found another library which is a little smaller in size. It is written for STM32F0 but I try to understand below function, is there a way to transfer it to STM32L1XX?
    void I2C_TransferHandling(
    I2C_TypeDef *   I2Cx,
    uint16_t        Address,
    uint8_t         Number_Bytes,
    uint32_t        ReloadEndMode,
    uint32_t        StartStopMode
    Is there equivalent in STM32L1xx?
          void I2C_WrReg(uint8_t Reg, uint8_t Dat){
            while(I2C_GetFlagStatus(DS_I2C, I2C_FLAG_BUSY) == SET);
            I2C_TransferHandling(DS_I2C, DS_ADDR, 1, I2C_Reload_Mode, I2C_Generate_Start_Write);
            while(I2C_GetFlagStatus(DS_I2C, I2C_FLAG_TXIS) == RESET);
            I2C_SendData(DS_I2C, Reg);
            while(I2C_GetFlagStatus(DS_I2C, I2C_FLAG_TCR) == RESET);
            I2C_TransferHandling(DS_I2C, DS_ADDR, 1, I2C_AutoEnd_Mode, I2C_No_StartStop);
            I2C_SendData(DS_I2C, Dat);
            while(I2C_GetFlagStatus(DS_I2C, I2C_FLAG_STOPF) == RESET);
            I2C_ClearFlag(DS_I2C, I2C_FLAG_STOPF);
  • Why this simple code fails to work
    while(1)
            TM_I2C_Start(I2C2, 0xD0, 0, I2C_ACK_ENABLE) ; //write mode
            TM_I2C_WriteData(I2C2, 0);                    //select register 0x0
            TM_I2C_Stop(I2C2);                            //stop
            TM_I2C_Start(I2C2, 0xD0, 1, I2C_ACK_ENABLE) ; //read mode
            sec = TM_I2C_ReadNack(I2Cx);
            sprintf(str," :\r\ns=%u",sec);
            uart_out_str(str);
    In debugger I get AF=1. why ack failures?
  • I tried a modification on the code written for eeprom. I see that I don't receive ack for address sent and in the debugger ADDR is never set so where is probably the problem?
  • Oh my God!!
    DS1307 supply voltage is 4.5-5.5V. this was the problem.
    After changing the supply from 3.3V to 5V the problem solved :)
