Hi, i have burned code in Teridian's 71M6541F IC which has 8051 15 core inside using Signum's ADM51 emulator. However, earlier code was working fine and I could see the output on LCD. I set one bit in one of the register which says" CONNECTS THE LCD POWER SUPPLY WITH BATTERY......after burning this modified code, I get message " Target initialization failed: No TCLK". I could not burn the flash now. Any solution please...
