Hello There,
I am trying to integrate the CAN driver for EA 4088 board for some time now. I am using the RTX based solution (CAN does not work without RTOS). I am not able to make it work. I am working with CPU speed of 120 MHz and Peripheral clock set to 60 MHz (The PCLKDIV is set to 0x02).
I am working with the CAN driver provided as part of Keil uVision 4.70 - RTX_CAN.c, CAN_LPC17xx.c, RTX_Config.c, and corresponding header files.
Are there any know issues with this driver?
Thanks atul
