I have interfaced AT89S52 with 16x2 LCD display and used following code. But nothing is being displayed on the display. Pls help me.
#include<reg51.h> sfr lcd_data_pin=0xA0; // data port P2 sbit rs=P3^0; // Register select pin sbit rw=P3^1; // Read write pin sbit en=P3^6; // Enable pin void delay(unsigned int msec) //delay function {int i,j; for(i=0;i<msec;i++) for(j=0;j<1275;j++); } void lcd_command(unsigned char comm) // function to send command to LCD { lcd_data_pin=comm; en=1; rs=0; rw=0; delay(1); en=0; } void lcd_data(unsigned char disp) // function to send data on LCD { lcd_data_pin=disp; en=1; rs=1; rw=0; delay(1); en=0; } lcd_dataa(unsigned char *disp) // function to send string to LCD { int x; for(x=0;disp[x]!=0;x++) { lcd_data(disp[x]); } } void lcd_ini() //Function to inisialize the LCD { lcd_command(0x38); delay(5); lcd_command(0x0F); delay(5); lcd_command(0x01); delay(5); lcd_command(0x06); delay(5); lcd_command(0x80); delay(5); } void main() { lcd_ini(); lcd_dataa("Samhitha"); delay(500); lcd_command(0x01); delay(5); lcd_command(0x06); delay(5); lcd_command(0x80); delay(5); lcd_dataa("GITAM"); delay(500); } Can anybody suggest me what could be the problem?
What was the result of your own debugging?
Have you verified all signals? All timing? All commands? How to tag source code when posting here?
