I have installed the keil v5.14 after that I try to run the keil program with new project. when I want to add new item to group 'source group 1', the "user code template" can't be open' how to handle this problem?
thanks..
The available user code templates depend on the software components that you have selected using the Manage Run-Time Environment dialog.
If you have not selected any component there are no templates available.
You may refer to www2.keil.com/.../mdk5-getting-started.pdf - Chapter: Create Applications for more information.
