Hi, I have a question and I was not able to solve it yourself. Is it possible using AGSI change the length of a command (in engine cycles). I need to do to correct the timer counts. I learned for example AGSI and realized that the number of machine cycles is specified in the core, not in the timer.
Looks like your 8051 implementation does not use standard clock cycles. Is this what causes the problem for you?
Yes, number of cycles is different from the standard 8051.
For example, the command "ADD A, #const" is performed in the standard implementation for 1 machine cycle, but in my 2-cycle engine.
