Hi All,
I'm using the CMSIS network component on STM32F407. To set a right MAC I'm reading it from external I2C EEprom and then I need to change the MAC of the system... Can't find any function to do this, only can see the #defines in the Net_Config_ETH_0.h but, obviously can't use it.
I'm not familiar with the CMSIS network component.
What about http://www.keil.com/support/man/docs/rlarm/rlarm_tn_runtimecfg.htm
See: own_hw_adr[6]
My project works ok with the RL-TCP library, but, I want to make all the project with the CMSIS librarys and RTOS.
Thanks 5375
Right. So the link I gave applies. I've used the same thing.
Hi
Solved.. thanks M Lurthurd :)
Finally the code looks like this:
extern ETH_CFG eth0_config; GetMACFromEEprom (); memcpy (eth0_config.MacAddr, SystemData.MAC, 6); net_initialize ();
The MAC is changed ok.
Thanks again.
