Running through code from a Book on the Cortex M0 by Yui. The code works for most of the examples with no problem. But I have a few questions.
1.) Looking at any of the RTX task examples they work correctly except I would like to see the events in the Event Viewer that is provided during Debug. I am using a ULINK2 but have not figured out how to get it to work. How to configure it so that the event viewer will work.
2.) There is a example of Dial controller which is something about using two Light sensors and a wheel that I guess casts a shadow with a light coming through as a line. So as the wheel is revolving you can determine with the sensor the speed of motion. The book does not describe how to build this circuit even though there is conceptual picture.
Thanks Gary
Thanks for the Answer. It was very infomative about the optical encoder. Think I will get one to see if I can get the project to work better.
Still would like to find out some information on the Event Viewer.
