I just updated Keil software pack and installed new component "ARM_Compiler". With this update I am not able to access FileSystem anymore.
Each time I call "fmount" function, return code is 9 (fsMediaError).
I selected Filesystem in "Compiler:IO" I didn t change anything else in my code.
I use filesystem with USB and MCI in the same time, both fail.
My board is based on a LPC4337 processor and I am sure the design is correct (if I switch to Keil Midlleware 6.2 and remove ARM_compiler, everything works fine).
Filesystem example doesn t work either.
Did I miss something with this update ?
