I'm trying to port code written for the CROSSWORKS_ARM_COMPILER to C51 and Keil will not accept the following definition:
typedef struct _FFS_FILE { DWORD directory_entry_sector; BYTE directory_entry_within_sector; DWORD current_cluster; BYTE current_sector; WORD current_byte; DWORD current_byte_within_file; DWORD file_size; union { struct { unsigned int file_is_open :1; unsigned int read_permitted :1; unsigned int write_permitted :1; unsigned int write_append_only :1; unsigned int inc_posn_before_next_rw :1; unsigned int access_error :1; unsigned int end_of_file :1; unsigned int file_size_has_changed :1; unsigned int reserved :8; } bits; WORD word; } flags; } FFS_FILE;
I get this error: ffs.h(131): error C141: syntax error near 'DWORD' ffs.h(131): error C129: missing ';' before 'directory_entry_sector'
I'm not well versed in C and any help will be appreciated. Thanks,
John
BYTE, WORD and DWORD aren't reserved data types in C.
So you need to include a header file that contains them. Or define them yourself.
#include <stdint.h> typedef uint8_t BYTE; typedef uint16_t WORD; typedef uint32_t DWORD;
Or if the compiler doesn't have stdint.h then the following works for a lot of compilers for 32-bit and smaller processors - but may get incorrect size depending on the actual size of short,int,long used by the compiler:
typedef unsigned char BYTE; typedef unsigned short WORD; typedef unsigned long DWORD;
Per,
Thank you, your suggestion worked. Apparently, Keil C51 does not have stdint.h but the definition of standard types did the trick.
Thanks again, John
