version 4.74 to 5.14 with legacy support produces a linker error
I am at a stage where I have some "time" to move to the newer tool but I have come across a problem and just wanted to see if others have had the same issue.
I have ver 4.74 installed in C:\Keil_4 and ver 5.14 installed in c:\keil_5 with the legacy support
I have changed the lib files I use in the project to the appropriate folders e.g. FS_CM.lib
and updated any drivers such as the SDIO
The code compiles with no errors as before but when linking I get the error L6405E rather than L6405W given in the linker error list in the books documentation.
I have tried deleting all output files and tool produced project files ( doesnt cure the issue)
Is this perhaps an installation issue e.g. not all has gone where I wanted it eg C:\Kiel_5 ?
thanks
Dan
  • Ok, but what's the error specifically complaining about? Something in the scatter file, or object files it doesn't like?
  • it complaining from
    .\Objects\ble_firmware_v1.axf: Error: L6405E: No .ANY selector matches main.o(i.app_error_handler).
    .\Objects\ble_firmware_v1.axf: Error: L6405E: No .ANY selector matches main.o(i.sys_evt_dispatch).
    .\Objects\ble_firmware_v1.axf: Error: L6405E: No .ANY selector matches app_timer.o(i.SWI0_IRQHandler).
    .\Objects\ble_firmware_v1.axf: Error: L6405E: No .ANY selector matches main.o(i.led_write_handler).
    I got the same error & I don't know how to solve and what caused this error
