lwip tcp abort error
Hello, Can any one tell me approx how many free space of RAM does lwip stack required?
LWIP stack is returning me error tcp_abort.
I am using lm3s6965 cortex m-3 processor and the processor has 64KB RAM & 256KB ROM. From that my application has used 50KB of RAM and 175KB of ROM. So is it the problem with memory?
Thanks in advance.
  • So what have you done to investigate the possible causes of that error?
    What does the LwIP documentation tell you?
    LwIP is Open-Source, so you can look and see what's happening - have you?
    savannah.nongnu.org/.../
    lwip.wikia.com/.../LwIP_Wiki
    lists.nongnu.org/.../lwip-users
  • Thank you, Andrew Neil, for ur response.
    I have referred all the links you have mentioned, and also lots more google link to find solution of my problem.
    Bt i find nothing relevant to my problem. I have also searched on keil's forum. bt there also they have given useful stuff relevant to my problem.
    I have 2 active tcp sockets.
    1. first socket works in tcp_listen mode. at power on this socket gets connected.
    2. second socket works in tcp_connect mode. this socket will try to connect with different tcp client socket one after other on the basis of tcp connection make and break concept.
    I have observed that my tcp_listen socket will be aborted by the lwip stack at random time period. bt my tcp_connect socket works fine.
    So i want to know is there any settings relevant to lwip parameters(MEM_SIZE, PBUF_POOL_BUFSIZE, PBUF_POOL_SIZE, etc...), which i am missing? This al parameters are set to default values given by lwip stack.
