I don't know, why I can't use float in my timer_callback function.
If I want to use a float variable in my timer callback function, the timer stops always after one round. Although I use a periodic timer. Do anyone know, how can I resolve this problem?
The sourcecode is written in uVision MDK-Lite Version 5.11.1.0.
Using a board or processor any of us might be familiar with? Is it faulting?
I use a MCB4300.
Have you thought of initilizing the FPU ? In the LPC_Open library code (fpu_init.c) their is a function:
/* Early initialization of the FPU */ void fpuInit(void) { // from arm trm manual: // ; CPACR is located at address 0xE000ED88 // LDR.W R0, =0xE000ED88 // ; Read CPACR // LDR R1, [R0] // ; Set bits 20-23 to enable CP10 and CP11 coprocessors // ORR R1, R1, #(0xF << 20) // ; Write back the modified value to the CPACR // STR R1, [R0] volatile uint32_t *regCpacr = (uint32_t *) LPC_CPACR; volatile uint32_t *regMvfr0 = (uint32_t *) SCB_MVFR0; volatile uint32_t *regMvfr1 = (uint32_t *) SCB_MVFR1; volatile uint32_t Cpacr; volatile uint32_t Mvfr0; volatile uint32_t Mvfr1; char vfpPresent = 0; Mvfr0 = *regMvfr0; Mvfr1 = *regMvfr1; vfpPresent = ((SCB_MVFR0_RESET == Mvfr0) && (SCB_MVFR1_RESET == Mvfr1)); if (vfpPresent) { Cpacr = *regCpacr; Cpacr |= (0xF << 20); *regCpacr = Cpacr; // enable CP10 and CP11 for full access } }
