I am trying to initialize this model of SRAM (R1LV0816ASB – 5SI) to my LPC1778. I am currently tracing my code result through the memtest code that I wrote but so far what I am seeing is let say in address 0x98000000 onwards is just value FF instead of incrementing numeric values. Already double checked the code, so a little advice would be good if you can help pinpoint on what to look at to possibly debug this would be much appreciated.
My init code is as follows:
static void pinConfig_SRAM(void) { //Select slew rate and also config for EMC use = 0x201 LPC_IOCON->P3_0 |= 0x201; /* D0 @ P3.0 */ LPC_IOCON->P3_1 |= 0x201; /* D1 @ P3.1 */ LPC_IOCON->P3_2 |= 0x201; /* D2 @ P3.2 */ LPC_IOCON->P3_3 |= 0x201; /* D3 @ P3.3 */
LPC_IOCON->P3_4 |= 0x201; /* D4 @ P3.4 */ LPC_IOCON->P3_5 |= 0x201; /* D5 @ P3.5 */ LPC_IOCON->P3_6 |= 0x201; /* D6 @ P3.6 */ LPC_IOCON->P3_7 |= 0x201; /* D7 @ P3.7 */
LPC_IOCON->P3_8 |= 0x201; /* D8 @ P3.8 */ LPC_IOCON->P3_9 |= 0x201; /* D9 @ P3.9 */ LPC_IOCON->P3_10 |= 0x201; /* D10 @ P3.10 */ LPC_IOCON->P3_11 |= 0x201; /* D11 @ P3.11 */
LPC_IOCON->P3_12 |= 0x201; /* D12 @ P3.12 */ LPC_IOCON->P3_13 |= 0x201; /* D13 @ P3.13 */ LPC_IOCON->P3_14 |= 0x201; /* D14 @ P3.14 */ LPC_IOCON->P3_15 |= 0x201; /* D15 @ P3.15 */
LPC_IOCON->P4_1 |= 0x201; /* A1 @ P4.1 */ LPC_IOCON->P4_2 |= 0x201; /* A2 @ P4.2 */ LPC_IOCON->P4_3 |= 0x201; /* A3 @ P4.3 */
LPC_IOCON->P4_4 |= 0x201; /* A4 @ P4.4 */ LPC_IOCON->P4_5 |= 0x201; /* A5 @ P4.5 */ LPC_IOCON->P4_6 |= 0x201; /* A6 @ P4.6 */ LPC_IOCON->P4_7 |= 0x201; /* A7 @ P4.7 */
LPC_IOCON->P4_8 |= 0x201; /* A8 @ P4.8 */ LPC_IOCON->P4_9 |= 0x201; /* A9 @ P4.9 */ LPC_IOCON->P4_10 |= 0x201; /* A10 @ P4.10 */ LPC_IOCON->P4_11 |= 0x201; /* A11 @ P4.11 */
LPC_IOCON->P4_13 |= 0x201; /* A13 @ P4.13 */ LPC_IOCON->P4_14 |= 0x201; /* A14 @ P4.14 */ LPC_IOCON->P4_15 |= 0x201; /* A15 @ P4.15 */ LPC_IOCON->P4_16 |= 0x201; /* A16 @ P4.16 */
LPC_IOCON->P4_17 |= 0x201; /* A17 @ P4.17 */ LPC_IOCON->P4_18 |= 0x201; /* A18 @ P4.18 */ LPC_IOCON->P4_19 |= 0x201; /* A19 @ P4.19 */
LPC_IOCON->P2_24 |= 0x201; /* /OE @ P2.24 ..EMC_CKE0*/ LPC_IOCON->P4_25 |= 0x201; /* /WEN @ P4.25 */ LPC_IOCON->P4_26 |= 0x201; /* /BLS0 @ P4.27 Lower Byte*/ LPC_IOCON->P4_27 |= 0x201; /* /BLS1 @ P4.27 Upper Byte*/
LPC_IOCON->P2_14 |= 0x201; /* /CS2 @ P2.14*/
void EMCInit (void) { //SRAM_INIT(); pinConfig_SRAM(); LPC_SC->PCONP |= 0x00000800;
//LPC_SC->EMCDLYCTL = 0x00001010; //LPC_SC->EMCDLYCTL |= (8<<0); //LPC_SC->EMCDLYCTL |= (8<<8);
//LPC_SC->EMCDLYCTL |= (8<<16); LPC_SC->EMCCLKSEL = 0x00000000; //CLCK = EMCCLK
LPC_EMC->Config = 0x00000000; LPC_EMC->StaticExtendedWait = 0x00; /* Configure memory layout, but MUST DISABLE BUFFERs during configuration */ /*The buffers can be enabled or disabled for static memory using the EMCStaticConfig Registers.*/ LPC_EMC->StaticConfig2 = 0x00000081; //16bit & active low lower and upper byte select
LPC_EMC->StaticWaitWen2 = 0x00000001; //WaitWen0+1 Delay from CHip Select to Write Enable LPC_EMC->StaticWaitWr2 = 0x00000001; // program the delay from the chip select to the write access LPC_EMC->StaticWaitOen2 = 0x00000001; // Chip Select to output enable or address change whichever is later LPC_EMC->StaticWaitRd2 = 0x00000001; //Chip select to read access //LPC_EMC->StaticWaitPage2 = 0x00000000; //Delay for asynchronous page mode sequential accesses for EMC_CS0. //LPC_EMC->StaticWaitTurn2 = 0x00000000; //Number of bus turnaround cycles EMC_CS0.
LPC_EMC->Control = 0x00000001; //May not be needed }
void Memtest(void) { volatile unsigned long *start= (volatile unsigned long *) 0x98000000UL; //volatile unsigned short *start= (volatile unsigned short *) 0x98000000; int value=0; int i; //for(i = 0; i < 1048576; i+= 4) for(i = 0; i < 128; i+= 1) //try just 32 bytes first. { *start = value; start++; value++; } }
int main(void) { EMCInit(); while(1) { Memtest(); } }
Ooppss the formatting is a bit off. The text indentation changed after I posted the message. My apologies.
That's why the instructions say to use PRE tags for source code.
There pre tagged...
static void pinConfig_SRAM(void) { //Select slew rate and also config for EMC use = 0x201 LPC_IOCON->P3_0 |= 0x201; /* D0 @ P3.0 */ LPC_IOCON->P3_1 |= 0x201; /* D1 @ P3.1 */ LPC_IOCON->P3_2 |= 0x201; /* D2 @ P3.2 */ LPC_IOCON->P3_3 |= 0x201; /* D3 @ P3.3 */ LPC_IOCON->P3_4 |= 0x201; /* D4 @ P3.4 */ LPC_IOCON->P3_5 |= 0x201; /* D5 @ P3.5 */ LPC_IOCON->P3_6 |= 0x201; /* D6 @ P3.6 */ LPC_IOCON->P3_7 |= 0x201; /* D7 @ P3.7 */ LPC_IOCON->P3_8 |= 0x201; /* D8 @ P3.8 */ LPC_IOCON->P3_9 |= 0x201; /* D9 @ P3.9 */ LPC_IOCON->P3_10 |= 0x201; /* D10 @ P3.10 */ LPC_IOCON->P3_11 |= 0x201; /* D11 @ P3.11 */ LPC_IOCON->P3_12 |= 0x201; /* D12 @ P3.12 */ LPC_IOCON->P3_13 |= 0x201; /* D13 @ P3.13 */ LPC_IOCON->P3_14 |= 0x201; /* D14 @ P3.14 */ LPC_IOCON->P3_15 |= 0x201; /* D15 @ P3.15 */ LPC_IOCON->P4_1 |= 0x201; /* A1 @ P4.1 */ LPC_IOCON->P4_2 |= 0x201; /* A2 @ P4.2 */ LPC_IOCON->P4_3 |= 0x201; /* A3 @ P4.3 */ LPC_IOCON->P4_4 |= 0x201; /* A4 @ P4.4 */ LPC_IOCON->P4_5 |= 0x201; /* A5 @ P4.5 */ LPC_IOCON->P4_6 |= 0x201; /* A6 @ P4.6 */ LPC_IOCON->P4_7 |= 0x201; /* A7 @ P4.7 */ LPC_IOCON->P4_8 |= 0x201; /* A8 @ P4.8 */ LPC_IOCON->P4_9 |= 0x201; /* A9 @ P4.9 */ LPC_IOCON->P4_10 |= 0x201; /* A10 @ P4.10 */ LPC_IOCON->P4_11 |= 0x201; /* A11 @ P4.11 */ LPC_IOCON->P4_13 |= 0x201; /* A13 @ P4.13 */ LPC_IOCON->P4_14 |= 0x201; /* A14 @ P4.14 */ LPC_IOCON->P4_15 |= 0x201; /* A15 @ P4.15 */ LPC_IOCON->P4_16 |= 0x201; /* A16 @ P4.16 */ LPC_IOCON->P4_17 |= 0x201; /* A17 @ P4.17 */ LPC_IOCON->P4_18 |= 0x201; /* A18 @ P4.18 */ LPC_IOCON->P4_19 |= 0x201; /* A19 @ P4.19 */ LPC_IOCON->P2_24 |= 0x201; /* /OE @ P2.24 ..EMC_CKE0*/ LPC_IOCON->P4_25 |= 0x201; /* /WEN @ P4.25 */ LPC_IOCON->P4_26 |= 0x201; /* /BLS0 @ P4.27 Lower Byte*/ LPC_IOCON->P4_27 |= 0x201; /* /BLS1 @ P4.27 Upper Byte*/ LPC_IOCON->P2_14 |= 0x201; /* /CS2 @ P2.14*/ } void EMCInit (void) { //SRAM_INIT(); pinConfig_SRAM(); LPC_SC->PCONP |= 0x00000800; //LPC_SC->EMCDLYCTL = 0x00001010; //LPC_SC->EMCDLYCTL |= (8<<0); //LPC_SC->EMCDLYCTL |= (8<<8); //LPC_SC->EMCDLYCTL |= (8<<16); LPC_SC->EMCCLKSEL = 0x00000000; //CLCK = EMCCLK LPC_EMC->Config = 0x00000000; LPC_EMC->StaticExtendedWait = 0x00; /* Configure memory layout, but MUST DISABLE BUFFERs during configuration */ /*The buffers can be enabled or disabled for static memory using the EMCStaticConfig Registers.*/ LPC_EMC->StaticConfig2 = 0x00000081; //16bit & active low lower and upper byte select LPC_EMC->StaticWaitWen2 = 0x00000001; //WaitWen0+1 Delay from CHip Select to Write Enable LPC_EMC->StaticWaitWr2 = 0x00000001; // program the delay from the chip select to the write access LPC_EMC->StaticWaitOen2 = 0x00000001; // Chip Select to output enable or address change whichever is later LPC_EMC->StaticWaitRd2 = 0x00000001; //Chip select to read access //LPC_EMC->StaticWaitPage2 = 0x00000000; //Delay for asynchronous page mode sequential accesses for EMC_CS0. //LPC_EMC->StaticWaitTurn2 = 0x00000000; //Number of bus turnaround cycles EMC_CS0. LPC_EMC->Control = 0x00000001; //May not be needed } void Memtest(void) { volatile unsigned long *start= (volatile unsigned long *) 0x98000000UL; //volatile unsigned short *start= (volatile unsigned short *) 0x98000000; int value=0; int i; //for(i = 0; i < 1048576; i+= 4) for(i = 0; i < 128; i+= 1) //try just 32 bytes first. { *start = value; start++; value++; } } int main(void) { EMCInit(); while(1) { Memtest(); } }
