I wrote a program, where some data is written to the internal flash of a stm32f4. If I am debugging everything works fine, but if the controller runs without the debugger, the data is not written.
Can somebody tell me why this happens?
Your code is broken? Or makes invalid assumptions?
Perhaps you are not setting things up properly, or expecting clocks/status to be in some specific state, and the debugger leaves them in a non-default state?
Without a debugger you can still output data via a USART, or status via GPIO/LED. Where exactly does your code, and flash programming/erasing sequence fall over?
I'd assume you'd at least need to unlock and clear the flash controllers flags/errors/status before starting.
