I am having an FS90R Continous Servo Motor with 3 wires.
1.Vss 5V
2.PWM Signal
3. Gnd
I have already initalized the PWM Signal through 16bit Timer Function from LPC11C24 Sample Program.
My PWM Port is PIO1_10/AD6/CT16B1_MAT1.
Can anyone tell me how to control this Servo Motor by moving clockwise and anticlockwise direction after Initalizing this PWM Signal.
Isn't it specified to rotate counter clockwise (CCW)? And expect a pulse between 900us and 1200us?
Stick your micro on a scope, and check that you have a 50Hz (20 ms) signal, and then adjust/modulate the pulse width in the range indicated above.
Thanks for your reply.
I have already set my prescalr,outpur signal,TCR , and the frq is set to be 50Hz.
Now my question,is how to initalize the servo motor with PWM Signal through programming and implemnent it through software
