Good Afternoon to all, I'm working with ARM processor LPC1768 in a MCB1700 board, and in my project i need to use uart to communicate with a PLC modem. I'm using the code bellow to do this. If a try to communicate with a Hyperterminal or similar on windows, my interruption works fine, but if a try to communicate with the before mentioned PLC modem, a can't get any interrupts. I have probed the uart pins P2.0 and P2.1 and the PLC modem pins, and i can see that my TX messages arrive on the modem, and i can see that the modem answer those messages accordingly, and i can see that the uart RX pin receives those messages, but no interruption are toggled...
Can anyone help me with this issue? any suggestion to other uart implementation?
//--------------------------------------------------------------------------- #include <LPC17xx.h> #include "Serial.h" //--------------------------------------------------------------------------- //--------------------------------------------------------------------------- // Defines //--------------------------------------------------------------------------- #define SW_FIFO_SIZE 512 #define RLS_INTERRUPT 0x03 #define RDA_INTERRUPT 0x02 #define CTI_INTERRUPT 0x06 #define THRE_INTERRUPT 0x01 #define LSR_RDR (1<<0) #define LSR_OE (1<<1) #define LSR_PE (1<<2) #define LSR_FE (1<<3) #define LSR_BI (1<<4) #define LSR_THRE (1<<5) #define LSR_TEMT (1<<6) #define LSR_RXFE (1<<7) #define UART_DISABLED 0x00 #define UART_OPERATIONAL 0x01 #define UART_OVERFLOW 0x02 #define UART_PARITY_ERROR 0x03 #define UART_FRAMING_ERROR 0x04 #define UART_BREAK_DETECTED 0x05 #define UART_CHAR_TIMEOUT 0x06 //--------------------------------------------------------------------------- //--------------------------------------------------------------------------- BYTE UART0_RxBuf[UART0_RX_BUFFER_SIZE]; BYTE UART0_TxBuf[UART0_RX_BUFFER_SIZE]; BYTE UART0_RxTail; BYTE UART0_RxHead; BYTE uart0_tx_sts; BYTE uart0_rx_sts; uint32_t rdaInterrupts = 0; uint32_t ctiInterrupts = 0; //--------------------------------------------------------------------------- //--------------------------------------------------------------------------- // Controle //--------------------------------------------------------------------------- void Serial0Init( unsigned int baudRate ) { int pclk, fdiv; LPC_SC->PCONP |= (1 << 3); LPC_PINCON->PINSEL0 |= (1 << 4); /* Pin P0.2 used as TXD0 (Com0) */ LPC_PINCON->PINSEL0 |= (1 << 6); /* Pin P0.3 used as RXD0 (Com0) */ LPC_SC->PCLKSEL0 &= ~(3 << 6); // clear bits LPC_SC->PCLKSEL0 |= (1 << 6); // set to "01" (full speed) pclk = SystemCoreClock; LPC_UART0->LCR = 0x03; /* 8 bits, no Parity, 1 Stop bit */ LPC_UART0->LCR |= (1 << 7); /* fdiv = (pclk/(16*baudRate)); LPC_UART0->DLM = (fdiv >> 8) & 0xFF; LPC_UART0->DLL = (fdiv) & 0xFF; */ // baudrate of 38400 with a clock rate of 100 MHz LPC_UART0->DLM = 0;//Fdiv / 256; LPC_UART0->DLL = 108;//Fdiv % 256; LPC_UART0->FDR = 0x21;/// LPC_UART0->LCR &= ~(1 << 7); LPC_UART0->FCR |= (0x0 << 6); //(0x3 = 14, 0x00 = 1) //LPC_UART0->FCR |= 0x01; //LPC_UART0->FCR |= 0x06; NVIC_EnableIRQ(UART0_IRQn); NVIC_SetPriority(UART0_IRQn,30); LPC_UART0->IER = 0x07; //Enable LPC_UART0->LCR = 0x03; } //--------------------------------------------------------------------------- void UART0_IRQHandler(void) __irq { BYTE intId, lsrReg; BYTE byData,bTmpTail; intId = ((LPC_UART0->IIR)>>1)& 0x7; if(intId == RLS_INTERRUPT) { //RLS lsrReg = LPC_UART0->LSR; if (lsrReg & LSR_OE) uart0_rx_sts = UART_OVERFLOW; else if (lsrReg & LSR_PE) uart0_rx_sts = UART_PARITY_ERROR; else if (lsrReg & LSR_FE) uart0_rx_sts = UART_FRAMING_ERROR; else if (lsrReg & LSR_BI) uart0_rx_sts = UART_BREAK_DETECTED; } else if (intId == RDA_INTERRUPT) { while((LPC_UART0->LSR) & 0x1) { UART0_RxBuf[UART0_RxHead] = LPC_UART0->RBR; UART0_RxHead += 1; if (UART0_RxHead == UART0_RX_BUFFER_SIZE) UART0_RxHead = 0; } rdaInterrupts++; } else if (intId == CTI_INTERRUPT) { while((LPC_UART0->LSR) & 0x1) { UART0_RxBuf[UART0_RxHead] = LPC_UART0->RBR; UART0_RxHead += 1; if (UART0_RxHead == UART0_RX_BUFFER_SIZE) UART0_RxHead = 0; } ctiInterrupts++; } } //---------------------------------------------------------------------------
If it works with Hyperterminal, and not with your Modem, perhaps you should be looking more closely at what exactly the modem is sending. ie What the signal is doing, not the software.
Look at the baud rate (bit timing), framing (bits, parity, stop).
If the USART isn't generating an interrupt, perhaps it isn't receiving valid data? Look at the status bits, etc.
The logic analyzer that i'm using can decode the serial data, and it checks the baud rate, and the framing, and it's all right. how i can check the status bit outside of the interruption?
Read LPC_UART0->LSR, Use a debugger?
And if you connect the modem to HyperTerminal with exactly the same settings that works?
You have the Rx and Tx senses correct (irrespective of the naming)
Are they correct?
