Hello All,
I am working on STM32F4 series & using Keiluvision4 as my IDE. In the startup file of my project i am reserving 4bytes space just after the vector table in the flash that would hold the Image size of that project.
I am reserving 4byte space at 0x08000200 using SPACE directive
Now I want that when I compile this project then the Image size of the project will be written to the reserved space(0x08000200) in flash.
I don't want to use the .map file for determining the Image size.
Thanks, Amit
www.keil.com/.../armlink_pge1362065951979.htm
Seems like an odd approach, there are unused vector entries that would suffice without carving out space in the middle of a code region.
Well you could post-process the AXF/ELF file, or use some AWK script against the .MAP file, it's not like you have to do such things manually.
On an ARM9 platform I used something like this to force the Linker to fix up it's own internal sizes into a know location.
IMPORT ||Image$$ER_IROM1$$RO$$Length|| IMPORT ||Image$$RW_IRAM1$$RW$$Length|| ... DCD ||Image$$ER_IROM1$$RO$$Length||+\ ||Image$$RW_IRAM1$$RW$$Length||
Thank u Westonsupermare Pier IMPORT & DCD worked, now i am able to obtain the Image size post compilation
Thanks once again :-)
