LPC4357 IAP bootloader - working only with ULink Pro
I'm writing bootloader for LPC4357. Bootloader is located at address 0x1A000000 and application binary image resides in external SPIFI FLASH.
After MCU finishes copying image into internal FLASH at address 0x1A010000, jump command is executed and application starts. This is true if I use Ulink Pro for code download and testing. If i use Flash Magic, bootloader hangs at first IAP write operation.
I'm using Keil MDK ARM 4.73. LPC4537 is running at 204 MHz. I'm not using RAM reserved for IAP operations. All IAP operations are completed successfully if I use Ulink Pro for download & run.
If I don't use IAP commands, code is working fine, regardless of programming tool used.
Any ideas?
uint32_t write_data (uint32_t cclk, uint32_t flash_address, uint32_t *flash_data_buf, uint32_t count)
   uint32_t i, ret, interrupts;
   disable_interrupts(interrupts);
   for (i = USER_START_SECTOR; i <= MAX_USER_SECTOR; i++)
      if (flash_address < sector_end_map[i])
         if (flash_address == sector_start_map[i])
            if ((ret = prepare_sector(i,i,cclk)) != 0)
               printf("prepare for erase failed (%d)\n", ret);
               while(1);
            WaitUs(1000 * 250); // not needed
            if ((ret = erase_sector(i,i,cclk)) != 0)
               printf("erase sector failed (%d)\n", ret);
               while(1);
            printf("prepare for write failed (%d)\n", ret);
            while(1);
         break;
   param_table[0] = COPY_RAM_TO_FLASH;
   param_table[1] = flash_address;
   param_table[2] = (uint32_t) flash_data_buf;
   param_table[3] = count;
   param_table[4] = cclk;
   iap_entry(param_table,result_table);
   enable_interrupts(interrupts);
   return result_table[0];
uint32_t erase_sector (uint32_t start_sector,uint32_t end_sector,uint32_t cclk)
   param_table[0] = ERASE_SECTOR;
   param_table[1] = start_sector;
   param_table[2] = end_sector;
   param_table[3] = cclk;
   param_table[4] = FLASH_BANK;
uint32_t prepare_sector (uint32_t start_sector,uint32_t end_sector,uint32_t cclk)
   disable_interrupts(0);
   param_table[0] = PREPARE_SECTOR_FOR_WRITE;
   param_table[3] = FLASH_BANK;
   enable_interrupts(0);
  • Consider what the debugger might be setting up or configuring. Look at the ULinkPro INI script, any unlock sequences, IAP initialization, register setting or remapping, etc.
  • I don't have any special code inside INI script, just issuing reset. I've tried adding equivalent code inside SystemInit() function but there is no difference in code behavior.
    Is there any special requirement before using IAP on LPC43xx platform?
    I've build bootloader for LPC1768 platform and everything works as it should. I don't have ULink Pro on that board.
    // UlinkPro INI script
    FUNC void Setup (void)
      // Reset peripherals: LCD, USB0, USB1, DMA, SDIO, ETHERNET
      _WDWORD(0x40053100, 0x005F0000);   // Issue reset
      _sleep_(1);
    Setup();                             // Setup for Running
