There are basically two ways to interface UART in 8051: 1) Receive by polling the RI register in the main() loop, Transmit by using printf finction. Advantage: it's easy. Disadvantage: it's tricky as the speed used to poll the RI register is not safe, in other words if the cpu is busy doing something else we might loose one or more characters depending on CPU and transmit speed. Furthermore printf() overhead eats a lot of ROM, on the other way formatting with printf is rather easy. 2) Transmit and receive using Interrupt: here we read RI and TI flags inside the UART ISR to know if the interrupt is for a transmitted or received frame, upon that we take or put another byte in the serial buffer SBUF0 until the transmission or receive is completed. Advantage: no character loss, the ISR will be able to send and receive all the frames. Disadvantages: is more complicated and despite my attempts I'm unable to use printf() to transmit, I need to send the characters one by one, additionally I cannot use the formatting service of printf(). I'm wondering if someone have a good idea to: a) Receive using Interrupt b) Transmit using printf() to merge the benefits of both techniques? Here my code:
// Global Variables unsigned char idata readBuffer[ READ_BUFFER_SIZE ]; // UART receiver buffer unsigned char code * writeBufferPtr; // UART transmitter buffer pointer volatile unsigned char readCount = 0; // number of bytes in write buffer volatile unsigned char writeCount = 0; // number of bytes in write buffer // // UART ISR void uartISR(void) interrupt 4 using 1 { uchar dummy; // handle buffered RX if ( RI0 ) { RI0 = 0; if ( readCount < READ_BUFFER_SIZE ) // receive data while buffer allows readBuffer[ readCount++ ]= SBUF0; else // when buffer is full, discard it dummy = SUBF0; } // handle buffered TX, in my attempts the entire if(TI0) statement has been removed to allow printf() to transmit if ( TI0 ) { TI0 = 0; if ( writeCount ) { // send data as long as it remains SBUF0 = *writeBufferPtr++; --writeCount; } } } //Receive routine example in the main() loop while ( readCount < EXPECTED_SISE ); // wait until a number of data is received // Handle the data on readBuffer[] here readCount = 0; // prepare for the next reception //Transmit routine example in the main() loop printf("Hello world!");
You can use printf() with polling or with interrupts.
It's just that you should arrange so that the data from printf() is not sent directly to the serial port but is instead stored in a circular buffer. Only if the UART transmit is idle should you "kick-start" the transmission with the first byte from printf() - then the ISR will pick up the following characters from the circular buffer as the UART continues to consume characters.
Only by using buffering can you get printf() to "instantly" return and let your main loop do something else, while the ISR takes care of sending out the buffered text.
Just look in the downloads section of this site!
