ARM9:"LOAD" a hex file cause a illegal address error.
Dear Keil Engineers: I use a debug.ini file to load my program. The debug.ini is as below:
     LOAD .\objs\program.hex
     LOAD .\objs\program.axf NOCODE INCREMENTAL
but which cause a error, some information show up that "error 57: illegal address (0x00000010)" I haven't selected the "Load Application at Startup" option in "Options for Target" page - "Debug". The hex file is as below:
:020000040000FA
:1000000018F09FE518F09FE518F09FE518F09FE5C0
:1000100018F09FE50000A0E114F09FE514F09FE5C3
I don't konw what's going on, why it cause error at address 0x00000010, the hex file is generated by the keil's tools.
If I don't use the debug.ini file to load program and select the "Load Application at Startup" option at "Options for Target" page - "Debug". That's OK!
Also it's OK to use my own flash programming algotithm to program the flash base at address 0x000000000, then start debuging.
I want to know what the "LOAD" command will do ? It will use the programming algorithm to program the flash?
Prompt reply will be greatly help for me!
Thanks,ppym
