Hi there, now i want to use RL-FlashFs to manage the nandflash on my board, however, the mcu i use ---lpc1822 does not have a nandflash controller and i access the nandflash by timing simulation, can i use the RL-FlashFs as well by adapting the driver routines ?
Use EMC (External Memory Controller) peripheral. In uVision folder ARM\RL\FlashFS\Drivers you can find a few NAND drivers which also use memory controler for driving NAND device.
Don't forget to enable software ECC in the configuration file (File_Config.c)
If your LPC1822 controller doesnt have an EMC (External Memory Controller) peripheral, then you can use SPI flash. File system can also be implemented on Serial flash memory.
Thank you very much for your answer, but i have connected the mcu with the nandflash via GPIOs, and access the nandflash by timing simulation, can i use the file system then ?
i have connected the mcu with the nandflash via GPIOs, and access the nandflash by timing simulation Have you ever asked the question why use on-chip timers when delays can be generated by software? or why use on-chip I2C communication registers when I2C communication can be done on GPIO too? if not, then you must find the answers to such question. and then i ask the question, why not use the dedicated EMC pins rather then using GPIOs?
Thank you for your answer, I have such a question because the circuit was not designed by me, and the designer did not realize that one day i would encounter such a problem. Anyway, thank you and i will try to redesign the circuit if the file system can not be applied under such a condition~
...because the circuit was not designed by me..... i will try to redesign the circuit wait before hitting the Panic button. just in case, if ur application can sufficiently handle the on-chip ram and hence there is no requirement of off-chip parallel RAM, and also if ur flash memory requirement are not much higher, instead of redesigning the board again, you can use SPI flash, if you have SPI connections.
...doesnt have an EMC (External Memory Controller) peripheral, then you can use SPI flash
To those who may encounter the same condition as i did: I have successfully manage the nandflash with Rl-FlashFs; and we do not need to perform LOW/LOW_EB formatting before FAT32 formatting.
