Hello..
I am working on a project in which i suppose to show string value(output of matlab reciving serially from pc ) on LCD. I am using 8051 microcontroller and interfaced LCD with it.
I checked 8051 coding and it is not working well, when i am transmiting data to it using matlab and receiving using serial communication it shows symbol lik E for each output like if the output string is ADE 679 it shows some kind of E symbol...please help..here is ma code #include <reg51f.h>
sbit rs = P3^7; sbit en = P3^6;
void lcd_init(); void lcd_data(char); void lcd_com(int); void delay(); char serial ();
void main() { char a; P0=0x00; SCON=0x50; TMOD=0x20; TH1=0xFD; TR1=1;
lcd_init(); while(1) { a = serial(); lcd_data(a); } }
void lcd_init() { lcd_com(0x38); delay(); lcd_com(0x0E); delay(); lcd_com(0x01); delay(); }
void lcd_com(int x) { rs=0; en=1; P0=x; en=0; delay(); }
void lcd_data(char y) { rs=1; en=1; P0=y; en=0; delay(); }
char serial() {
while(RI==0); RI=0; return SBUF; }
void delay() { int i=0; for(i=0;i<1000;i++); } So where is the problem? Thank you.
Step #1
How much of a delay do you expect your delay function would have?
It is going to be very awkward to determine the actual delay and that delay might change on a recompilation.
Consider a better delay and consider what sort of delays you really need.
www.8052.com/.../162556
