howto: function library in separated hex-file
Due to the lack of flash memory i want to move code parts in a separate function library and locate the same in RAM. I thought to use the LIB166 and assign certain code modules to the RAM-address area.
In addition i want be able to build and deploy (download) this RAM function library without the need to build&programm the flashed code again. Means i need the hex-files: flashcode.h86 and functionlib.h86.
Is there a way to create a functionlib.h86 with the LIB166 and L166 which shares certain interface functions to a flashcode.h86? Or are there any alternative solutions?
  • But RAM is volatile. So you need to store any code you want to run from RAM in either the flash, or some (possibly serially connected) external non-volatile memory.
    Are you sure that you have selected the correct processor for your task? The processor selection process is one of the most important steps in a development process.
  • I've a technical solution where a host-application always downloads via a USB-connection volatile data into the RAM and then invokes commands to the Infineon C167CS MCU.
    I intend to just attach the functlib.h86 to the download data and eg. invoke then any further functionlib-attach procedures (if necessary).
    So ja, the MCU C167CS seem to set correctly.
    Per, thank you for your response.
  • THE BEST WAY YOU STORE EACH FUNCTION CODE IN A HEX FILE. LOAD IT ONLY WHEN NEEDED.
  • What you're describing is a Dynamically-Linked Library (DLL).
    The Libraries used by C166 are (designed to be) Statically-Linked - so you have a whole bunch of work to do to implement the dynamic linking...
  • "THE BEST WAY YOU STORE EACH FUNCTION CODE IN A HEX FILE. LOAD IT ONLY WHEN NEEDED."
    Besides managing to scream like a pig, your suggestion is also impractical. If each hex file has function object code statically linked, then each hex file is designed to load at one very specific address - which must not collide with any address range needed by another function that also needs to be called within a similar time frame.
    So if all these hex files just represents non-overlapping object code, then there is no reason for not concatenate them into a single hex file and load.
    Come back when you besides SCREAMING also have a good solution for dynamically relocating hex files while loading them, so they can be loaded at any address. First with dynamic relocation support will your suggestion be viable.
  • @Andrew: ja, even i thought at a 1st glance i've to the whole Dynamic Link Lib bunch.
    And in fact, that can be solution.
    However it think it is not necessarily required. For my embedded device/ use case a general static link could be still sufficient. But what i need is to break up the static link/build into two separated hex-files.
    So i've eg. one solution in mind:
    1. Reserve a RAM-Area and allign interfacing functions (addresses) to a RAM-Address area.
    (in case of a need assign for each function a dedicated address)
    2. Build (static link) the whole stuff - leads to one total hex-file eg. flashcode.h86
    3. Extract from flashcode.h86 the reserved RAM-Area parts to a separate functionlib.h86
    4. Flash the flashcode.h86 and later download the functionlib.h86 on demand.
    5. In case of required modifications in functionlib.h86, modify the code and do steps #2-#4 again except NOT to program the flashcode.h86 again.
    What i dont like at this solution that there will be a lot of proprietary convetions/rules for the build steps.
    I'd prefer more a tricky solution which could be done with the given C166 Tool chain only.
  • @Per and Andrew:
    A further solution #2 could be as followed - while using the C166 toolchain only.
    (in case of a need assign for each function a dedicated address).
    3. Now create a further/new c-module which contains a dummy main().
    Now build a 2nd h86 functionlib.h86. Means build the dummy main() together with the modules cotaining the interface functions to a functionlib.h86 file. (ensure to have the use the same reserved RAM-Addresses as given in step#1.
    4. Flash the flashcode.h86. The target will have some code loaded in the RAM which of course is volatile.
    5. Download functionlib.h86 from the host-app on demand - means prior before any functionality of these interface functions are required.
    But before i dig more into this solutions i thought i'll ask this forum for help.
    Because i imagine that i am not the only one in the world with the issue:
    "Lack of flash-size" ,"extend code-space by using RAM"
  • "Lack of flash-size" ,"extend code-space by using RAM"
    The thing is, with most microcontrollers, the RAM size is significantly smaller than the Flash size - so this doesn't generally make a lot of sense.
    Rather than try to make the architecture do things it was never intended to, might it be better to seek-out a chip that's actually equipped for your task?
    Are you stuck with the C167CS ?
  • @Andrew:
    yes i am stuck with the C167CS! I want to do software maintenance for hardware which is out in the field. And I have 512KB RAM (~256KB free) and total 1MB Flash. Moving code-fragements of size ~5-10KB to the RAM would already meet my purpose.
    So it is worth to look into this.
