Can I use this function in the keil uVision? (This function worked well in IAR Embedded Workbench)
moveInterruptVectorToRam();
/**************************************************************************//** * @file ram_interrupts.c * @brief Moves the interrupt vector to RAM * @author Energy Micro AS * @version 1.07 ****************************************************************************** * @section License * (C) Copyright 2013 Energy Micro AS, http://www.energymicro.com ******************************************************************************* * * Permission is granted to anyone to use this software for any purpose, * including commercial applications, and to alter it and redistribute it * freely, subject to the following restrictions: * * 1. The origin of this software must not be misrepresented; you must not * claim that you wrote the original software. * 2. Altered source versions must be plainly marked as such, and must not be * misrepresented as being the original software. * 3. This notice may not be removed or altered from any source distribution. * 4. The source and compiled code may only be used on Energy Micro "EFM32" * microcontrollers and "EFR4" radios. * * DISCLAIMER OF WARRANTY/LIMITATION OF REMEDIES: Energy Micro AS has no * obligation to support this Software. Energy Micro AS is providing the * Software "AS IS", with no express or implied warranties of any kind, * including, but not limited to, any implied warranties of merchantability * or fitness for any particular purpose or warranties against infringement * of any proprietary rights of a third party. * * Energy Micro AS will not be liable for any consequential, incidental, or * special damages, or any other relief, or for any claim by any third party, * arising from your use of this Software. * *****************************************************************************/
#include <string.h> #include "em_device.h"
/* Find the correct size of the interrupt vector */ #if defined(_EFM32_GECKO_FAMILY) #define VECTOR_SIZE (16+30) #elif defined(_EFM32_TINY_FAMILY) #define VECTOR_SIZE (16+23) #elif defined(_EFM32_GIANT_FAMILY) #define VECTOR_SIZE (16+38) #else #error "Unknown Vector size" #endif
/* Align the RAM vector table */ #if defined (__ICCARM__) #pragma data_alignment=256 uint32_t vectorTable[VECTOR_SIZE]; #elif defined (__CC_ARM) uint32_t vectorTable[VECTOR_SIZE] __attribute__ ((aligned(256))); #elif defined (__GNUC__) uint32_t vectorTable[VECTOR_SIZE] __attribute__ ((aligned(256))); #else #error "Undefined toolkit, need to define alignment" #endif
/* SysTick interrupt handler. Counts ms ticks */ //volatile uint32_t msTicks = 0;
/* Place interrupt handler in RAM */ #if defined (__ICCARM__) /* IAR compiler */ __ramfunc #elif defined(__CC_ARM) __attribute__ ((section ("ram_code"))) #elif defined(__GNUC__) /* GCC based compilers */ #if defined (__CROSSWORKS_ARM) /* Rowley Crossworks */ __attribute__ ((section(".fast"))) #else /* Sourcery G++ */ __attribute__ ((section(".ram"))) #endif #endif
//void SysTick_Handler(void) //{ // msTicks++; //}
void moveInterruptVectorToRam(void) { memcpy(vectorTable, (uint32_t*)SCB->VTOR, sizeof(uint32_t) * VECTOR_SIZE); SCB->VTOR = (uint32_t)vectorTable; }
Looks like a regular memcpy(), what you'd need to be conscious about is where it's copying the data, and if that has been carved out of the memory space, so the linker doesn't use that RAM for other purposes. The vector table likely also has to fall on a 512-byte boundary.
Thanks!
