RTX First project - when built it is missing first part of the code
It must be a novice question but I have been trying for days without success.
I created RTX First project example using PDF guide but when I built the project and started the simulation it didn't even get to init task. Then I built the already finished project in Full project folder and started the simulation. This one worked fine.
I soon realized that built projects have different code sizes. Full project is 6020 bytes and RTX First project is 5468 bytes in size. Their first part is different.
<RTX First project> starts like this:
0x00000000  E59FD00C  LDR       R13,[PC,#0x000C]
                 _main_scatterload:
0x00000004  EB00029F  BL        $Ven$AT$I$$__scatterload(0x00000A88)
                 __main_after_scatterload:
0x00000008  E59F0000  LDR       R0,[PC]
0x0000000C  E12FFF10  BX        R0
0x00000010  00000528  ANDEQ     R0,R0,R8,LSR #10
                 __rt_final_cpp:
0x00000014  40000D38  ANDMI     R0,R0,R8,LSR R13
And Full project starts like this:
0x00000000  E59FF018  LDR       PC,[PC,#0x0018]
   605:                 LDR     PC, Undef_Addr
0x00000004  E59FF018  LDR       PC,[PC,#0x0018]
   606:                 LDR     PC, SWI_Addr
0x00000008  E59FF018  LDR       PC,[PC,#0x0018]
   607:                 LDR     PC, PAbt_Addr
0x0000000C  E59FF018  LDR       PC,[PC,#0x0018]
   608:                 LDR     PC, DAbt_Addr
0x00000010  E59FF018  LDR       PC,[PC,#0x0018]
   609:                 NOP                            ; Reserved Vector
   610: ;               LDR     PC, IRQ_Addr
0x00000014  E1A00000  NOP
Looks like the project created using PDF guide is missing first part of the code. I tried multiple timer from the start. Step by step using PDF guide and same problem happens each time so please help.
I am using uVision V4.73.00 on Win7 Professional.
