After setting the start bit the SI flag is not getting set.therefore not entering the isr routine. Can anyone tell me why?
void i2c_init() { PINSEL0=BIT4+BIT6; //scl=port0.2 sda port0.3 IODIR0=BIT2+BIT3; I2C0CONSET=BIT6; // enable I2C0CONCLR=BIT5+BIT2; I2C0SCLH=75; I2C0SCLL=75; /*i2c interrupt enable*/ VICIntSelect=0x00; VICIntEnable=BIT9; VICVectAddr4=(unsigned) slave_addr; VICVectCntl4=0x29; } void read() { lcd_data('r'); I2C0CONSET|=BIT5; // START BIT lcd_data('s'); } __irq void slave_addr(void) { I2C0CONCLR=BIT5; // clear the start bit switch(I2C0STAT) { case 0x08 : I2C0DAT=0xa0; break; } I2C0CONCLR=BIT3; // clr si flag VICVectAddr = 0x00; } int main() { i2c_init(); lcd_init(); lcd_data('m'); read(); }
