Is possible to enable vnc server in emWin library?
hello
I've found in the user manual of emWin (by segger) that you can run a vnc server instead of the Graphical LCD
Is this Feature supported in the keil?
additional info:
1,when i change this line in example i got compile error { #define GUIDEMO_USE_VNC (0)}
2,I think it is no because the emWin is not compatible with the RL-TCPnet
if it is no how can i run a vnc server in keil Graphical library?
