MDK 5.01 does not support ST.NXP peripherals lib
MDK 5 have a big problem and bug that you can not use ST,NXP or non-KEIL peripheral drivers for cortex M devices,or if you do not use keil soft packs for using non-Keil drivers then you can not work with keil middlewares ,because they are dependent on keil drivers and driver layer is not independent.
I think these modification must be done in future:
- allows us to use user selected driver(Keil or ST or custom driver)
- middle wares should have a driver api functions that make them independent from other parts and can work with keil or ST or ... driver
- we can add ST driver lib as a software pack to keil.
I hope keil understand user needs and do it in future,Our codes for STM32 are dependent on ST peripheral driver and ST lib is very perfect and professional.but keil drivers for STM32 are not perfect and complete and keil must use vendors provided drivers because vendor drivers are better and perfect , keil have no time to write huge number of drivers for many cortex m devices.
  • Do you think keil drivers for USART or SPI are perfect and contain all feature of peripheral hardware?
    Do you think keil can provide perfect driver for all cortex micros and all peripherals with common API?
    If I can start with keil 5.01 and use ST peripherals driver and keil middle ware please guide me .
  • and you think that ST's "drivers" are perfect?!
  • You can add whatever you want into your project. Any library, any source file or any other file, just the same way as before in uVision 4 ;)
  • If we can make a project for stm32 without using keil device drivers then we can continue with MDK.
    We want to use our ST lib drivers for stm32 (not keil drivers),at keil 5.01 I think this not possible there is conflict.
    Keil middleware drivers also depends on keil driver or is not usable with ST driver lib.
    I think keil must define perfect and complete API drivers for each peripherals that inclue most features then give it to users with source.I think this is a very time consuming task for keil.
    btw,adding components to project without using softpacks is not possible I think keil must allow us to use or not use any part of soft packs.
    regards
  • it seems that some drivers have some limitations,for example SPI driver do not have SPI4,5,6 so we can not use SPI4,5,6 of stm32f427.
    If APIs are common between all cortex M device this is good idea for better code development.
    However a cortex M micro hardware may not support an API function.
    Regards
  • The current version of the SPI driver was built for the STM32F40x series. It will be extended in a future release of the STM32F4xx DFP to cover all STM32F4xx including the 42x and 43x.
    To prevent a misunderstanding about the CMSIS-DRIVERS layer: Its purpose is not to fully cover all peripherals with all special features that a specific device has to offer. It is designed to give higher level middleware (TCP/IP, USB, etc) or drivers (like e.g. a SPI touchscreen controller driver) a known HAL with a known set of common functions.
  • I'm converting working ST lib project into MDK5 software pack project and it seems to be very hard. I can get GPIOs and UARTs working from software packs but then starts the problems...
    There is no DAC implemented in the software pack and therefore I need to add it from ST lib. As far as I have understand, it should be possible by just adding a stm32f4xx_dac.c to the project and compiling this file with USE_STDPERIPH_DRIVER defined (in file options). Resulting software will go through SystemInit but never reaches the start of main(). Please, can anyone explain step by step how to add ST stuff to MDK5 project?
  • Hi
    I am also using STM32Fx products. The software packs are a step forward in making it easier for programmers looking forward - positive. uVision 5 is good as far I am concerned.
    The problems with ARM MDK5 for users are:
    1 The majority of the example programs are still in uVision 4 and are not utilizing software packs.
    2 A vendor knows its peripherals the best and therefore programmers will prefer using its peripheral firmware - hopefully all CMSIS compliant.
    3 It is clear that many programmers at this stage are struggling with the uVision 5 and vendor peripheral specific firmware integration in a project. In a RTX project the problem seems to be worse. Try retargetting for an example. Went through documentation, examples (all MDK 4 and lower and there is the problem) File dependencies seems to be problematic - can you clear this up?
    I hope that somebody at KEIL is reading this:
    Please supply documented simple example projects to your customers addressing the problems stated above. The current example projects for MDK 5 does not address these problems.
    Please include examples for RTOS and non RTOS applications.
    Using printf for debugging purposes (retargetting)is an easy way for debugging and should be covered in the examples please (STM32FxDISCOVERY boards?).
    I see I am not alone in this. If there are documentation in MDK 5 context available which I am not aware off, can somebody please point me to the solution. Looking forward to the solution.
    Matze
