Hello, I works with µVision v 5.0.5.15, and when I build my ARM project, all files are always rebuild ! I found on the net, that the problem can be the TZ system variable. But in my PC (Windows 7) there is no this variable. I found on the net, that "Create Bath File" on Target/Output menu, should not be selected. It's true for me.
would you have an idea for my problem ?
thank you for your help. Best regards
