i use RL Flash-FS for lpc 1788 but i cant write in file when size of file is more than 4095Byte. after 4095byte receive crc error
I can write 1MByte in file but same data like AAAAAAAAAAAAAAAAAAAAAA... The error occurs when the characters are not the same like ABABABABABAB...
Could there be a problem with your hardware implementation?
Check the IO hardware/software outside of the file system.
