When I set "Number of Telnet Connections" to 1,telnet Connection works for one time.(I know that this configuration means on simultaneous connection.) I disconnected telnet connection every time when I connected,but when I want to connect to it again its not work.(ping is available).
Whats the problem?
It seems disconnect procedure don't alert the TCP-stack and doesn't clear its flag for new connection.
Thanks.
I think this information my be useful: 1.TCP_CM3.lib 2.this is the keil telnet example on v4.7
I find the answer. I forget to call timer_tick() every 100ms, after that everything is OK.
