STM32F439 FSMC -> FMC
Is there anybody who knows when STM32F439 will be supported in MDK 5.0 ?
Actually there is no support for SDRAM and FSMC_STM32f4XX.c can't compile since
FSMC object don't exist any more (transfered to FMC).
I can write my own code for FSMC initialisation, but this things with software components and drivers looks very interesting to me.
Is there possibility to correct/add current code and then release it under new version of component?
Thank you ,Martin.
  • Hello Martin,
    you should check out the File System example for the MCBSTM32C development board. The MCBSTM32C uses the FSMC for addressing the on-board GLCD. You find it in the Pack Installer Examples tab. Copy this example and open it. Under the green Board Support icon you will find the GLCD_16bitIF_STM32F10x.c file. There are some settings for the FSMC.
    Kind regards,
    Christopher
