STM32L - USB HID and Windows 8.1
I have developed a USB device based on STM32L151, working with Keil pro (v4.60) USB stack, and it was working great with Windows XP, 7 and 8. But since the PC was updated to Windows 8.1, the RTX Kernel crashes and my USB device goes to os_error() with a OS_ERR_FIFO_OVF as soon as Windows accesses it (for instance when I refresh the list of the devices in the peripheral manager)
It seems that the usb_init() function fails, and thus the device crashes when it receives a usb command.
The odd thing is that when I try to access it with my hid application on PC it works, provided I send the first commands as soon as I've plugged the device (I guess I don't let the time to Windows to handle the device).
Am I the only one to get this behavior ? Is there a solution to make Keil's USB stack compliant with Windows 8.1 ?
Thank you
  • For the moment I got rid of the crash by simply removing the RTOS of my program, since it's not mandatory for this device. It seems to work like a charm, additionnal tests are currently being performed.
    The other projects that need an RTOS will be self powered, so I assume the first solution you suggested will be enough.
    Not the finest ending, but I can't spend more time on it for the moment.
    Thank you again for your help Tsuneo, it has been really appreciated,
    Regards
