Hi everybody. I'm LouisKhanh.
I have a LCD.h for LCD 16x2 on stm32f1 from my friend. However, my board is STM32f4 so I have to change it to version for stm32f4 but sadly, it didn't work. Below is my LCD.h version.Please help me to fix it ! Thanks you for reading !
/* Define to prevent recursive inclusion -------------------------------------*/ #ifndef __LCD_H #define __LCD_H
#ifdef __cplusplus extern "C" { #endif
/* ************************************************************************************************************************************* * INCLUDED FILES * ************************************************************************************************************************************* */ #include "stm32f4xx.h"
/* LCD Control pins----------------------------------------------------- */ #define LCD_RS_GPIO_PORT GPIOD #define LCD_RS_GPIO_CLK RCC_AHB1Periph_GPIOD #define LCD_RS_GPIO_PIN GPIO_Pin_1
#define LCD_RW_GPIO_PORT GPIOD #define LCD_RW_GPIO_CLK RCC_AHB1Periph_GPIOD #define LCD_RW_GPIO_PIN GPIO_Pin_2
#define LCD_EN_GPIO_PORT GPIOD #define LCD_EN_GPIO_CLK RCC_AHB1Periph_GPIOD #define LCD_EN_GPIO_PIN GPIO_Pin_3
/* LCD Data pins----------------------------------------------------- */ /* No need because of 4 bits mode b*/ #define LCD_D4 GPIO_Pin_4 #define LCD_D5 GPIO_Pin_5 #define LCD_D6 GPIO_Pin_6 #define LCD_D7 GPIO_Pin_7 #define LCD_DATA_GPIO_PINS (LCD_D4|LCD_D5|LCD_D6|LCD_D7) #define LCD_DATA_GPIO_PORT GPIOC #define LCD_DATA_GPIO_CLK RCC_AHB1Periph_GPIOC
/** * @brief LCD command for HD44780U */
/* LCD memory map */ #define LCD_LINE0_ADDR 0x00 // Start of line 0 in the DD-Ram #define LCD_LINE1_ADDR 0x40 // Start of line 1 in the DD-Ram //#define LCD_LINE2_ADDR 0x14 // Only for LCD 20x4: start of line 2 in the DD-Ram //#define LCD_LINE3_ADDR 0x54 // Only for LCD 20x4: start of line 3 in the DD-Ram
/* LCD Commands */ #define LCD_DD_RAM_PTR 0x80 // Address Display Data RAM pointer #define LCD_CG_RAM_PTR 0x40 // Address Character Generator RAM pointer #define LCD_CLEAR_DISPLAY 0x01 // Clear entire display and set Display Data Address to 0 #define LCD_RETRN_HOME 0x02 // sets DDRAM address 0 and returns display from being shifted to original position. #define LCD_DISP_INIT 0x28 // function set is 4 bit data length and 2 lines #define LCD_INC_MODE 0x06 // Entry mode is display Data RAM pointer incremented after write #define LCD_DISP_ON 0x0C // Sets entire display on, cursor on and blinking of cursor position character #define LCD_DISP_OFF 0x08 // Sets entire display off, cursor off #define LCD_CURSOR_ON 0x04 // turn on cursor #define LCD_CURSOR_OFF 0x00 // turn off cursor #define LCD_CUR_MOV_LEFT 0x10 // Cursor move and shift to left #define LCD_CUR_MOV_RIGHT 0x14 // Cursor move and shift to right #define LCD_BUSY 0x80 // LCD is busy
/* ************************************************************************************************************************************* * PRIVATE TYPE DEFINE * ************************************************************************************************************************************* */ /* GPIO configuration mode */ typedef enum { Input = 0, Output } GPIOConfig_Mode_TypeDef;
#define SET_LCD_RS_Line() GPIO_SetBits(LCD_RS_GPIO_PORT, LCD_RS_GPIO_PIN) #define CLR_LCD_RS_Line() GPIO_ResetBits(LCD_RS_GPIO_PORT, LCD_RS_GPIO_PIN) #define SET_LCD_RW_Line() GPIO_SetBits(LCD_RW_GPIO_PORT, LCD_RW_GPIO_PIN) #define CLR_LCD_RW_Line() GPIO_ResetBits(LCD_RW_GPIO_PORT, LCD_RW_GPIO_PIN) #define SET_LCD_EN_Line() GPIO_SetBits(LCD_EN_GPIO_PORT, LCD_EN_GPIO_PIN) #define CLR_LCD_EN_Line() GPIO_ResetBits(LCD_EN_GPIO_PORT, LCD_EN_GPIO_PIN)
void lcd_data_line_write(u8 data); u8 lcd_data_line_read(void); void lcd_data_line_conf(GPIOConfig_Mode_TypeDef IO_mode); // initializes I/O pins connected to LCD void lcd_Init_HW(void); // waits until LCD is not busy void lcd_Busy_Wait(void); // writes a control command to the LCD void lcd_Control_Write(u8 data); // read the control status from the LCD u8 lcd_Control_Read(void); // writes a data byte to the LCD screen at the current position void lcd_Data_Write(u8 data); // reads the data byte on the LCD screen at the current position u8 lcd_Data_Read(void);
// initializes the LCD display (gets it ready for use) void lcd_Init(void); // moves the cursor/position to Home (upper left corner) void lcd_Home(void); // clears the LCD display void lcd_Clear(void); // moves the cursor/position to the row,col requested // ** this may not be accurate for all displays void lcd_GotoXY(u8 row, u8 col); // prints a series of bytes/characters to the display void lcd_Print_Data(char* data, u8 nBytes);
#ifdef __cplusplus } #endif
#endif /* __LCD_H */
/******************* (C) COPYRIGHT 2009 ARMVietNam *****END OF FILE****/
So why don't you get your friend to help you with this?
Because my friend are doing his senior project, so he can't help me. Therefore, I'm seeking help from all of you. Please !!
sure and you believe someone, for free, will look through a big chunk of code or, maybe compile it, buy the processor you have and debug it.
what you need to do is to START DEBUGGING and, if you by doing that can state "if i stop on point x the xxx SFR holds yyy and that seems wrong" then help will be forthcoming.
If, however your problem is "I have no idea what I'm doing and expect the given code to work" good luck
I think you misunderstood what i wrote. Because the message is limited, so i can only post the main file for you.
void RCC_Configuration(void) { /* Setup the microcontroller system. Initialize the Embedded Flash Interface, initialize the PLL and update the SystemFrequency variable. */ //SystemInit(); } int main(void) { /* Configure the system clocks */ RCC_Configuration();
/* initialize LCD */ lcd_Init();
lcd_Clear(); /* print message on LCD */ lcd_GotoXY(0,0); printf("Hello World"); lcd_GotoXY(1,0); printf("LOUISKHANH");
while (1) { /* Insert delay */ Delay(100); } }
