LPC2388: Using USB OHCI and SD/MMC at the same time
I have to use both usb host as mass storage with USB stick and MMC card with the LPC2388.
I successfully took the examples MSD_FILE for usb sticks and SD_FILE for sd-cards and integrated that in my own application separately.
But when I try to activate both interfaces the finit(NULL) call takes significantly more time and returns 1.
I'm using the MCB2300 eval board at the moment. The following changes I made with the original examples:
In the file usbh_ohci_lpc23xx.c I changed the
Start address of memory used by OHCI to 0x7FD02000
as the Memory Card Drive 0 uses 0x7FD00000 as Base address for the Relocate Cache Buffer.
In the file File_config.c I cleared the checkbox of Default Drive [U0:].
If I deactivate the USB Flash drive 0, the finit(null) call returns successfully 0 and I 'm able to use the SD-card.
What do I miss in my project to use both of that interfaces?
Thanks in advance and best regards
Hubert
  • Ok, I found the mistake!
    in the finit call I have to give the "M0:" as argument even if it's checked as default drive.
    Now everything works.
    finit("M0:") successfully initializes the sd-card
    and
    finit("U0:") successfully initializes the usb stick.
    regards
    Hubert
