I would like to know if you have to do reset of the program I recorded on LPC1342, make him miss the paragrama recorded. Because I was trying to use pin 29 as SCK0 after that he can not record anything more on-chip
when I try to record it does not recognize JTEG.
can someone help me?
If you program wrong content into the processor that does something unsupported with clock timing or other critical parameters, then you can get into a situation where JTAG will not work.
Any option to do ISP using UART?
