Flash download using Keil ulink2
I have Toshiba MCU series TMPM32F. Recently I tried programming it using keil Ulink2 debugger. When I try to flash the code, the device itself is not detected. Further to this when new debugger is connected, it tries to update FW and fails. What can be the reason for this?
Any help would be appreciated.
Sandeep.
  • Pity you don't give the error message, or more specific details of how it "fails"
    You might want to go to the options/settings for the ULink 2 selection, go to the Flash tab and make sure you have selected an appropriate flash algorithm for the chip you are using.
    Under the Ulink 2 selection you should also be able to see what devices it has identified. Try SWD vs JTAG, if it still doesn't see any devices check you have things powered and cabled suitably.
